Kick stand weld failure
- CHARLESRAD
24 Oct 2005 21:03
Just picked up a 1982 kz 750 Twin CSR M1 today. Purchased off E-bay with 6799 miles execellent riding condition, however during shipping the kickstand lower weld was tore. It is hanging on by the top weld. Need some suggestions should I have it welded or remove it? Replacing it with an aftermarket kickstand?
- ejshotgun
Re: Kick stand weld failure
24 Oct 2005 21:11
If it isn't mangled I'd just weld it back. Of course that depends on if you can weld or if you have someone available to weld it.
- steell
24 Oct 2005 21:42
That's not unusual, the weld was broke in the same place on a 77 750B frame that I am using in a project. I just bent the kickstand back to it's normal position and welded it.
As far as removing it, keep in mind that the 82 750 twin does not have a center stand, and the frame lacks the mounting for a center stand.
Post edited by: steell, at: 2005/10/25 00:44
