bigger tire = different swing arm?
- kz1k
- You Cant Fix Stupid!
15 Sep 2010 18:31
hi guys. i was reading and saw people are using a Suzuki GS swingarm in order to use a larger rim and tire. does it matter what size gs it comes off of? are there any other swing arms that can just be bolted on for a decent price used?
my bike frame is a KZT00A-030869
THANKS .......JOE
THANKS .......JOE
1978 KZ1000A2
- MFolks
Re: bigger tire = different swing arm?
15 Sep 2010 18:44
Depends on how big of a rear tire you're planning on using, then figure in offset sprockets for the engine and possible need for a bearing assembly in the sprocket cover to prevent wear on the engine's output shaft(where the engine sprocket mounts).
Some offset sprocket makers:
www.sunstar-mc.com/home.aspx
www.rebelgears.com/
www.schnitzracing.com
www.jtsprockets.com
www.pmfronline.com
www.rebelgears.com/
www.jtsprockets.com
www.pmfronline.com
- 9am53
- homebrew, and some bbq
16 Sep 2010 04:41
Maybe this will be of some interest, but the swingarm from my 83 gpz1100 (I think it's a stock swinger) is almost 1.5 inches wider and 2" longer than the stocker on my kz1000...
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
'71 CB350
- stonemaster
16 Sep 2010 19:46
9am53 wrote:
what about the pivot, does it match as far as width?? i know the diameter is the same or at least i think it isMaybe this will be of some interest, but the swingarm from my 83 gpz1100 (I think it's a stock swinger) is almost 1.5 inches wider and 2" longer than the stocker on my kz1000...
