Chain Clearance? 630 to 530
  • squints
  • squints's Avatar Topic Author
14 Sep 2010 16:56
#398732
I know there are many threads on the 530 conversion, but heres one more.
I want to swap in the 530 chain on my 82kz1000m. I'm currently running a 16F/39R sporkets with a 96 link 630 chain and I hope to swap in a 17F/43R with a 112 link 530 chain.
Heres my question: Will I run into and chain clearance issues?
I could not locate diameter measurements for the 530 sprockets, any help there would be great.
Has anyone else done the 530 conversion to their Kz1000 "J" engine? Any comments on the proposed sprockets?
Thanks
traded my classic Kz's for a 2001 Kz1200r
Upstate NY
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
Re: Chain Clearance? 630 to 530
14 Sep 2010 17:49 - 14 Sep 2010 17:50
#398744
I did the 530 chain conversion on my 81 KZ1000 M1, and there were no clearance issues at all. The sprockets have more teeth, but are close in diameter.
I believe mine are 15/40, as they didnt have the 16 front at the time, but it makes no difference, as ive done the 16 on others.
Good luck.
B)
PS. 15/40 makes her real quick! :laugh:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 14 Sep 2010 17:50 by TeK9iNe.
  • Old Man Rock
  • Old Man Rock's Avatar
14 Sep 2010 17:59
#398751
530 and 630 pitch chains are ~ the same size at 3/8ths of an inch wide.....
Maybe this will help....
kzrider.com/index.php?option=com_docman&...d&gid=428&Itemid=108
Go through the calculations for the gearing your looking for....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • squints
15 Sep 2010 18:40
#399002
Good luck.
B)
you remember what length chain you got?
Upstate NY
  • TeK9iNe
  • TeK9iNe's Avatar
17 Sep 2010 09:33
#399319
Good luck.
B)
yeah, I think it was a 110.
If you just call Z1 Enterprises, they will tell you exactly what you need for sprockets, chain, etc. in no time at all. They're extremely helpful for this stuff!
Good luck.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
