To seafoam or not to sea foam
- Iron Duke
- what are you rebelling against?
14 Sep 2010 13:56
One small question about Seafoam: Is seafoam safe to use in M C gas tanks after it has been sealed/lined with any of the products for this,do any of these additives have MEK, or anything else in them that would pull the liner loose,degrade it in any way so as to impar the running or life of the bike?
1982 KZ550 LTD C-3
1979 XS1100 F Yamaha
- TeK9iNe
- What did you do!?!
Re: To seafoam or not to sea foam
14 Sep 2010 14:01
I have run SeaFoam in several coated tanks with no problems.
Good luck.
Good luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- hocbj23
14 Sep 2010 14:30
Running Seafoam in my coated tank-no problems noted.bj
- larrycavan
14 Sep 2010 16:09
Iron Duke wrote:
Where the hell is Otto when you need him anyway
- hocbj23
14 Sep 2010 16:39
cooking up another formula in his lab.bj
- Old Man Rock
14 Sep 2010 17:39
OK, stupid thing for me to think about here but..... Have to go with it anyways :blush: ...
Unless wanting to run a whole tanks worth through the carbs, why not use a external 1/2 gallon - 1 gallon tank instead...
Example, carb sync hanging tank...
Just a thought...:blush:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- TeK9iNe
14 Sep 2010 17:43
Old Man Rock wrote:
Thats an absurd level of though for this forum! Tisk, tisk!
:laugh: :woohoo: :laugh: :silly:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Old Man Rock
14 Sep 2010 18:01
Think of it as a IV KZ pole...
Oh hell, sell them on E-bay for big $$$$...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- PLUMMEN
14 Sep 2010 18:32
Old Man Rock wrote:
oh god i picture dave sitting in a chair next to his bike with an iv stand and his color tune hooked up like his visiting somebody in a hospital,dont give him any ideas! :woohoo:OK, stupid thing for me to think about here but..... Have to go with it anyways :blush: ...
- otakar
15 Sep 2010 05:40 - 15 Sep 2010 05:45
larrycavan wrote:
Sorry guys I went fishing yesterday afternoon. :blush: :whistle: :whistle: The "Seafoam" is fine to use in the lined tank. I however have found new and better products since than. "Seafoam" has changed it's formula over the last few years and is not as good as it used to be. Besides that the price went up quite a bit. I now use the Lucas oil products. For deep cleaning like, I used to use "Seafoam" in the old days, I use Lucas, "deep clean Fuel System Cleaner" #10512. For every day maintenance, which I run in EVERY tank full, I run Lucas "Fuel Treatment" #10003. Personally I buy it in the gallon bottles #10013, because I run it in every vehicle I own, and at all times. I find that the engines run much smoother and give me better gas millage, when I do. I run the "Fuel System Cleaner" in my cars about every 3 months, and every 1000Mi in my bikes. I find the Lucas 10512 product as good if not better than "Seafoam" and quite a bit cheaper.
Iron Duke wrote:One small question about Seafoam: Is seafoam safe to use in M C gas tanks after it has been sealed/lined with any of the products for this,do any of these additives have MEK, or anything else in them that would pull the liner loose,degrade it in any way so as to impar the running or life of the bike?
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 15 Sep 2010 05:45 by otakar.
- sparkn
15 Sep 2010 06:16
I use the Lucas fuel treatment myself but did not know there was a "deep cleaning" version of it. It must be doing something because I now leak fuel out of every orifice on the bike. Must've cleaned out the gunk that was being used as gaskets. I guess I should have expected that from a 31 year old bike that in all likelihood has never had a gasket replaced (had 6900 miles on it when I bought it). I don't mind. It needed it anyway. There isn't a piece of rubber in and around the motor that isn't as hard as a twig from an oak tree.
1979 KZ650 SR
- otakar
15 Sep 2010 06:21 - 15 Sep 2010 06:25
It is relatively a new product. It has been around about two years or less I believe. It retails for $12, but I have bought it for as little as $6. Most of the large chain automotive stores carry it.
www.lucasoil.com/products/display_produc...l%20System%20Cleaner
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 15 Sep 2010 06:25 by otakar.
