short rider kz1000 LTD
  • kz1k
  • kz1k's Avatar Topic Author
  • You Cant Fix Stupid!
13 Sep 2010 10:48
#398268
hi guys. i am about 5'5" tall 190 lbs. short stalky prick...lol. my roomate who is helping me with my build has suggested we lower the bike. what are some ways to go about this? he has an idea, i just wanted to run it by the forum.
1978 KZ1000A2
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: short rider kz1000 LTD
13 Sep 2010 10:53
#398271
raise the fork tubes and shorter rear shocks
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • kz1k
13 Sep 2010 11:08
#398272
wont that just raise the front and drop the rear?
1978 KZ1000A2
  • thechief86
  • thechief86's Avatar
  • tuck in behind me, i'll show ya where to crash!
13 Sep 2010 12:24
#398281
loosen the triple tree and let it slide down the forks, when the bike is at your desired height, tighten them mofos back up.
1980 kz1000
22k miles(for now)
kerker 4 into 1,
mikuni carbies,
k&n pods,
mag wheels,
drag bars,
shiny paint :D
loud, low, and fast.
possible cafe project.
vin# KZT00B526919
  • kz1k
13 Sep 2010 12:25
#398282
ill have to try that...thanks
1978 KZ1000A2
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
13 Sep 2010 12:26
#398283
sportster shocks have been used to lower the rear.a nice gsxr frontend and 17" wheel would be a nice way to lower the front and get 2000 + suspension and brakes.
  • kz1k
13 Sep 2010 12:57
#398287
$ is a issue. so well see. can i losten the triplr tree and slide forks up to lower on this bike? would i have to cut the forks?
1978 KZ1000A2
  • 531blackbanshee
  • Vendor
  • Vendor
13 Sep 2010 13:28
#398293
no cutting just slide the legs up towards the bars however much you can(before they hit the handlebars)or want to.struts are a cheap easy way to lower the back.it'll feel like you are taking one up the dukechute every time you hit a bump tho :laugh: .or so i hear:ohmy: .
  • racer54
  • racer54's Avatar
13 Sep 2010 19:15 - 13 Sep 2010 19:17
#398397
Just remember if you move front forks up through the triple trees that you are shortening distance between bottom tree and fender. Tree is much harder then that front fender and will not have any mercy on that thin metal fender. I have a few fenders to prove it! There are also brackets that mount to rear shocks and the lwer mounts that move bottom of shock back about an inch or so to help lower the bike. I use shocks that are about 1 1/2" shorter to touch ground flat foot. Can't remember the brand as it was many years ago but you can find shorter shocks if you look around. You can also put a spacer in the lower fork legs to lower the front forks to any distance you want. Just cut the spacer the required amount. You can buy them but they are just aluminum tubing. I have even heard guys use PVC pipe but not sure how that would hold up. Been told KZ650 forks are shorter and I know H2 forks are...that's what I use on my bike.
Last edit: 13 Sep 2010 19:17 by racer54.
