confused about rim sizes
- Topper
13 Sep 2010 08:10
I've got a 1988 KZ305 LTD with some badly corroded spoke wheels.
I'd like to replace the wheels and am trying to figure out what size rims I need.
My tire sizes are:
front: 90/90-19
rear: 120/90-16
Will any 19" rim work for the front? and any 16" for the rear? Or do I need specific widths?
If I find used rims off a different KZ model/year are they likely to be compatible?
Thanks!
My tire sizes are:
front: 90/90-19
rear: 120/90-16
Thanks!
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
1979 KZ750 Twin
- H1Vindicator
Last edit: 21 Feb 2013 20:50 by H1Vindicator.
Re: confused about rim sizes
13 Sep 2010 08:45
axle size and hub width are two main concerns.speedo drive has to be takin into consideration as well.
how bout just buying some new rims(hoops)off ebay that have the right diameter and width with the proper amount of spoke holes and getting some spokes from www.buchananspokes.net/
and getting the new rims laced on to your hubs?
just a thought,hth.
just a thought,hth.
- Topper
13 Sep 2010 09:09
Actually the rims and hubs aren't in too bad of shape. They're probably salvageable. It's the spokes that are really toasted.
Looks like a new set of spokes would cost about $100 per wheel. Any idea what it costs to have the spokes replaced?
1979 KZ750 Twin
1979 KZ750 Twin
- Nebr_Rex
13 Sep 2010 10:13
Topper wrote:
You could do it your self.
Have the tire removed.
All that is needed is a spoke wrench,a set of
jack stands and a way of measuring run out.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Topper
13 Sep 2010 12:40
So if I do decide to replace the wheels, I need to look for rim diameter, axle size, what else?
Is there any resource out there where I can look up which other KZ years/models might have wheels that are compatible with mine?
1979 KZ750 Twin
1979 KZ750 Twin
