77-80 KZ1000 axle dimensions needed
  • mjg15
  • mjg15's Avatar Topic Author
13 Sep 2010 07:05 - 13 Sep 2010 07:08
#398203
Could someone please measure the length between threads and the diameter of axle. Also need the OD and length of the outer nuts that are in the forks. I need the type shown below , which I believe to be 77-80,
Thanks
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
Last edit: 13 Sep 2010 07:08 by mjg15.
  • testarossa
  • testarossa's Avatar
Re: 77-80 KZ1000 axle dimensions needed
13 Sep 2010 07:49
#398214
If you don't get your answer by the time I get home, I should be able to help.
Bumperooski
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • mjg15
13 Sep 2010 09:22
#398243
Bumperooski
Sounds good. Your bike looks great !!
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
  • testarossa
13 Sep 2010 15:39
#398319
mjg15 wrote:
Bumperooski
Thanks boss, I try.
Here's the measurements.
Overall length = 9.220"
Axle diameter = 0.667"
Threaded section on either end is M16x1.5 at 1.020" long each including the chamfer up to the axle diameter (0.667')
Center section length between M16 threads 7.180"
The large nuts on either end are as follows
27mm hex that is approx 0.295" long
Overall length is 1.700"
The captured section is 0.944" diameter at 1.405" long.
My actual measurements were taken from a 1978 KZ1000A2 front axle. Hope this helps. Don't be afraid to ask if something doesn't make sense.
2004 ZX-10R
Angola, IN
  • mjg15
13 Sep 2010 19:02
#398393
Makes good sense AND it's the size that I need to mount my 1300 wheel to my Police front end without any machining or bearing swap/alterations. Nice. I'm off to Ebay, unless you'd want to sell that one ?
Thanks for the response, much appreciated !
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
  • testarossa
13 Sep 2010 22:32
#398506
Send me a pm with a fair price and I'll let you know. Include your shipping info, so I can get a shipping quote. Do you need the speedo drive, and the spacer as well? One thing that I was holding on to it for was to sort out the gear ratio in the speedo drive in comparison to my GSXR unit. I can accelerate that process if necessary.
2004 ZX-10R
Angola, IN
