1976 KZ400D3 parts swap
- Kitten Tooth
12 Sep 2010 23:01
Im starting a cafe build with my 81' KZ1000LTD.. I was going to use the tripple tree, forks, swingarm, rear shocks, brakes, wheels and tires off the the KZ400 that i just bought and put them on my KZ1000. So far, the only things that im worried about seting up is the swingarm and the tripple tree. I check the diameter of the fork tubes and they're too small to fit into the stock triple tree on my KZ1000. If i swap tripletrees, do i have to get bigger bearings of bushings or something to that affect to fit them into the headtube of the kz1000 frame? Also, if the swingarm is too small do i need bushings or spacers to fit it?
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- loudhvx
Re: 1976 KZ400D3 parts swap
13 Sep 2010 00:01
I'm no expert, but I really don't think that is a good idea. That will make the bike very dangerous to ride, in my opinion.
The KZ400 forks are only 33mm. They will flex like crazy when hitting bumps and especially braking. The frame and suspension on the 400 are really only up to the task of a small bike.
Why exactly are you wanting to swap these parts? Are the original 1000 parts bad?
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Nebr_Rex
13 Sep 2010 06:32
Kitten Tooth wrote:
Did someone fall on their head?
On my KZ400 I went to 36 mm forks and a 55 swingarm.
It makes no sence to go smaller (ie. weaker).
:laugh: :ohmy: :huh: :silly:Im starting a cafe build with my 81' KZ1000LTD.. I was going to use the tripple tree, forks, swingarm, rear shocks, brakes, wheels and tires off the the KZ400 that i just bought and put them on my KZ1000. So far, the only things that im worried about seting up is the swingarm and the tripple tree. I check the diameter of the fork tubes and they're too small to fit into the stock triple tree on my KZ1000. If i swap tripletrees, do i have to get bigger bearings of bushings or something to that affect to fit them into the headtube of the kz1000 frame? Also, if the swingarm is too small do i need bushings or spacers to fit it?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Kitten Tooth
13 Sep 2010 20:00
I wanted the single disk brake and spoke wheels on the front... Is there a way to swap out wheels? both front and back. I thought they looked cooler:D
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- Kitten Tooth
13 Sep 2010 21:25
Could i just swap out wheels? i like the look of the spokes better and i think that single disc in the front looks really sharp too. The only thing i was worried about was the rear sprocket being off centered from the output sprocket with that smaller wheel.
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- Nebr_Rex
14 Sep 2010 10:48
Kitten Tooth wrote:
Try CSR 650 or 1000.
Aluminum rims,19 front and 16 rear.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
