Any issue with sandblasting front master cylinder?
- psrumors
09 Sep 2010 09:44
About to rebuild the front master cylinder and the paint looks like crap. I thought about blasting all the paint off and hitting it with some clear. I'd polish it but don't have the time.
Thoughts?
And yes it will be thoroughly cleaned prior to reassembly
Thoughts?
'82 KZ1000-K2 LTD
- bikerjim
- 1986 T-type Regal
Re: Any issue with sandblasting front master cylinder?
09 Sep 2010 09:55
You might consider using paint stripper instead. You surely would not want any accidental blasting to the interior of the cylinger.
1959 Sears moped, 49cc
50's/60's Peugeot moped, 49cc
50's Mustang motorcycle
1959 Royal Enfield Indian Chief, 700cc
1979 KZ750B, owned since new
- psrumors
09 Sep 2010 10:48
The issue I think with paint stripper would be it attacking the seal on the sight glass. I assume there is a rubber seal under the chrome ring around the glass.
'82 KZ1000-K2 LTD
- trianglelaguna
09 Sep 2010 11:03
i'm just starting to use my new sand blaster...but i notice if i duct tape and exacto knife clean edged any not to be blasted areas,then screw the piece through an existing hole to a piece of pine,then screw the pine to a tree at head/shoulder height...the piece works down quicker...the piece cant get damaged by rolling awya or flipping around, and i can walk around it to hit tight spots and the tape peels away leaving anything needed undamaged...
so yes you could easily sand blast it as long as you duct tape the important areas...this is how i will be doing small parts from now on and it works tits
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- Kidkawie
- I bleed premix
09 Sep 2010 11:48
I used blue masking tape to protect my frame tag from sandblasting.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- bikerjim
- 1986 T-type Regal
09 Sep 2010 14:32
"...this is how i will be doing small parts from now on and it works tits"
Right on!! I like working these, too!!
