Experts!! Really Hard Question
  • 771000KZ
  • 771000KZ's Avatar Topic Author
07 Sep 2010 13:45
#396828
so I am doing over a 77 KZ 1000. I got it in pieces and the rims were kinda crap, I have a 80 GS750 parts bike and the rims are great and have new tires, bearings and balance ect, so I am going to use them, I got them all bolted up and shimmed to center etc.
here it the hard question, I have to use the GS speedo drive will it read true with the KZ speedometer? or will I have to use a GS speedo or after market speedo? I'd like to know before I spend the times retoring the gauges.
Thanks guys!
  • Lorcan
  • Lorcan's Avatar
  • Speed Loony
Re: Experts!! Really Hard Question
07 Sep 2010 13:57
#396831
I'm pretty sure the speedo drives of that era all have the same internal ratio so it should be fine.
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
  • 771000KZ
07 Sep 2010 14:40
#396838
thx. no another hard one (i think). what is the stock sprocket for the rear, with the suzy rear tire I have to use the suzy sprocket which is like 44 or 45 teeth, the one on the KZ hub has only 33 (which isn't stock is it?) and the front is 15 teeth (630 chain). What is the proper teeth for a rear sprocket?
  • 771000KZ
07 Sep 2010 15:02
#396844
I just ordered 530 conversion, 17 front and 41 rear. what ratio will that be?
  • MFolks
  • MFolks's Avatar
07 Sep 2010 15:23
#396846
When changing sprocket ratio's, I use www.gearingcommander.com
  • hocbj23
  • hocbj23's Avatar
07 Sep 2010 16:12
#396855
Both ur current and new ordered ratios are 1:2.2.
  • 771000KZ
07 Sep 2010 16:16
#396856
sorry, I was wrong it was a 43 rear that I ordered not a 41.
  • larrycavan
  • larrycavan's Avatar
07 Sep 2010 16:17
#396857
33T rear would be for LTD with 16" wheel or someone swapped the 35 for a 33 to drop RPM a little.
Measure circumference of the rear tire and I'll give you your exact MPH in whatever gear you want with RPM of the motor..
  • Nebr_Rex
  • Nebr_Rex's Avatar
07 Sep 2010 19:17
#396902
15/33 = 2.2:1
17/43 = 2.53:1
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
