Rear drum to disk swap
  • warmmushroom
  • warmmushroom's Avatar Topic Author
05 Sep 2010 07:43
#396253
I have a 77 kz650 b and after a a long ride from Regina, Sask to Tofino, BC (about 3500kms roundtrip)mostly through the mountains I have decided I will prob. live longer if I upgrade the brakes on this bike. Current stock brake system is in great condition pads disk drums shoes etc are all in like new condition, however they just didnt cut it on high speed through the twisties. Front brake was useless once it started raining and the rear brake heats up too much and isn't that great anyways. I would like to switch to a dual disk front caliper with a more modern disk and switch the rear drum to a disk but I want to keep the stock size spoke wheels. I was looking at a friends 2007 suzuki vstrom and the front caliper will fit without hitting the wheel although the mounting holes are a bit off. Any thoughts....has anyone done this?
  • T_Dub
  • T_Dub's Avatar
Re: Rear drum to disk swap
05 Sep 2010 08:04
#396256
I would do the front dual disk swap, there are many examples of such things. I'm sure the Fish or someone who has done it will chime in. But why switch the rear? IMO, it looks better with the drum, and once you upgrade the front the need for a powerful rear brake will be gone.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
  • M357.5
  • M357.5's Avatar
  • Kwakas N' lots of em'
05 Sep 2010 08:12
#396259
KZ1000 double disks and calipers are a direct bolt on. A rear setup off a 76-79 KZ750B ( complete wheel ) would likely be an easy retrofit as well, you'd need a brake stay mount welded onto the swingarm for the caliper and a mount for the master on the frame. Not a direct fit but not too hard to do.
Check out www.fishheadbigbrakes.com/
Lots of info and pic's there to give you an idea of what it takes to mount modern brakes to your spoke wheel.
83 KZ750L X2 + goodies = Project
84 KZ750L the mini ELR replica replica lol
84 ZX750E Turbo modded n' FAAAAASSSSSSTTTTT
85 GPz900r GREEN N' MEAN
05 Sep 2010 08:48
#396262
You might want to consider getting the parts from a KZ650 C model. They would be easier to adapt then something from a different species. Ed
  • warmmushroom
05 Sep 2010 08:50
#396263
I agree that the rear looks better with the drum however after many hours of riding through the curviest roads I've ever seen the rear brake started to heat up...a lot. It was raining and there was steam pouring off of it. I prob should have let the engine do a little more of the braking but I still feel that the brake system is inferior and I would feel much more at ease if the brakes could handle some abuse. Front duals from a kz1000 would be perfect I'm assuming I will need to change the master cylinder to a dual as well.
  • otakar
  • otakar's Avatar
05 Sep 2010 08:53
#396264
A rear wheel and swingarm from a 77/78 KZ1000 would be a direct bolt on. Same with the front brakes. The harder part will be mounting the rear master cylinder. You will have to weld on some brackets for thtat.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
05 Sep 2010 11:24
#396288
warmmushroom wrote:
...long ride...3500kms...through the mountains...high speed through the twisties... Front brake was useless once it started raining and the rear brake heats up too much and isn't that great...after many hours of riding through the curviest roads I've ever seen the rear brake started to heat up...a lot. It was raining and there was steam pouring off of it...
High speed in rain though twisties on a strange road :ohmy:
Brilliant, and probably won't be the brake's fault when the inevitable happens. ;)
Good Fortune! :)
  • PLUMMEN
  • PLUMMEN's Avatar
05 Sep 2010 17:13
#396338
kz1000 swingarm needs to be narrowed maybe 1/4" total on pivot tube
  • warmmushroom
18 Sep 2010 15:01
#399684
If I wanted to live long I wouldn't be riding an antique bike now, would I?
