drag bike gearing help
- bwill166
03 Sep 2010 10:51
hey all, building a 75 kz900 drag bike with a 1400 kit, back cut gears, air shifter, extended swing arm, drag tire. want to run low 9's. whats a good combo on front and rear sprockets as far as teeth numbers go? what rpm would u set ur low launch at? what about upper rev limit? shift rpm? i know ive asked for everything short of u comin over and helping build it(if ur in kc mo area come on!) but any experience will help. this is first time out on 2 wheels at the drags. thanks all
- timebomb33
Re: drag bike gearing help
03 Sep 2010 11:56 - 03 Sep 2010 11:57
if your using the kz trans then i'd use something like 16 front 39 rear if your using a gpz trans then you might try 15 or 16 front around 47 rear just because of gearing differences between the 2 tranny's also it depends on what tire your using as well.
I THINK MY POWERBAND BROKE
Last edit: 03 Sep 2010 11:57 by timebomb33.
- Jack
03 Sep 2010 12:10 - 03 Sep 2010 12:11
A couple of questions- KZ900 tranny or? Head and cams you plan to use ? Weight of you & bike?
To run low 9's on a small tire bike you're going to need a good cylinder head and cams combo as well working on gearing. It's been a long time since I ran a small tire bike but used 16-38 in a 1394cc. with Cam Motion Z9/Z10 cams/KZ head that flowed 104 cfm. Went 9:10 to 9:25 all day at +- 600 lbs.total weight.
Set 2 step was at around 7000 and shifted at 10250. Limiter usually around 11250 and used good valve springs.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
Last edit: 03 Sep 2010 12:11 by Jack.
- jayw704
04 Sep 2010 07:53
1978 KZ1000
Go Loud and go fast or dont go at all!!!
- big mike
13 Sep 2010 14:29
kz trans use a 16 front and a 42 rear unless your only like 140 wet lol go with this and have fun if you have any Qs just pm me ok i have ben running kz in drag racing for over 20 years i have tones of parts if you need any thing
