KZ1000P11 wheel swap help please
  • MrD_KZ1000p
  • MrD_KZ1000p's Avatar Topic Author
02 Sep 2010 14:26
#395665
ok so i got a k1000p11 that came with 18 inch front and rear wheels. prob is the rotors are shot. A freiend of mine gave me a set of wheels from a 85 ltd750 it had the 19 inch front with 16 inch rear. Can i put these set of wheels on my kz100p11? I am short so i wanted to lower the rear anyways. can someone please help.
  • otakar
  • otakar's Avatar
Re: KZ1000P11 wheel swap help please
02 Sep 2010 15:00
#395676
Yes the rear wheel will interchange but the front will not without a new tree.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • MrD_KZ1000p
02 Sep 2010 18:07
#395706
thanks for the help, what about the rear sprocket will it change the gearing and also do i need to shorten me chain?
  • MrD_KZ1000p
02 Sep 2010 18:08
#395707
new tree or forks? is this due to the brake caliper location?
  • otakar
  • otakar's Avatar
02 Sep 2010 19:10
#395717
It should actually be the entire front end because the P tree is over an inch wider and the brake mounts on the lower forks are also about a quarter inch higher.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • MrD_KZ1000p
02 Sep 2010 22:03
#395774
