Dragging Caliper
  • likes2gofast2009
  • likes2gofast2009's Avatar Topic Author
Dragging Caliper
01 Sep 2010 10:13
#395391
My rear caliper seems to be dragging... Haven't had a chance to take a closer look at it yet but was wondering if you guys had some possible causes of this that you could share??
1980 KZ1000 LTD "Brandi"
4-1 Kerker
Dyna Coils
More to come this winter!
  • TexasKZ
  • TexasKZ's Avatar
Re: Dragging Caliper
01 Sep 2010 10:42
#395401
Three of the more common causes are-
1. Rust/dirt/crud on the pedal pivot.
2. Rust/dirt/crud in the caliper.
3. Rust/dirt/crud on the caliper slides or pins.
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
01 Sep 2010 10:55
#395406
Believe it or not I've had success by just pumping some clean fluid through the caliper.
I'd try that along with everything TexasKZ suggested before I tried to rebuild the caliper.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • testarossa
  • testarossa's Avatar
01 Sep 2010 11:02
#395408
Might also check the pads to ensure that they are not too worn. Extremely thin pads can lead to piston over-extention, causing the piston to cock in the bore. The piston then becomes stuck.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • bountyhunter
  • bountyhunter's Avatar
01 Sep 2010 11:38
#395416
Mine was dragging because the lube on the caliper pins was old and gunked so the caliper couldn't float like it's supposed to.. I removed the pins (one at a time) and put new lube on and it worked great.
  • loudhvx
  • loudhvx's Avatar
01 Sep 2010 11:54
#395417
Try the other simpler things first, but if it ends up that you need to rebuild the caliper, pay special attention to the groove that the piston seal sits in. That groove needs to be clean because that is what retracts the piston. When the piston moves out, the square cross section of the rubber seal deforms outward into the chamfer of the groove. When you let up on the pedal, the ruber seal tries to restore its shape, and this is what retracts the piston a tiny bit.
  • likes2gofast2009
02 Sep 2010 04:07
#395535
Swet, thanks for all the reply's guys!
4-1 Kerker
Dyna Coils
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
02 Sep 2010 04:13
#395537
Lack of maintenence... ;)
+ all of the above and the manual.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
