CHAIN
- JEFFG1
CHAIN
23 Aug 2010 05:43
wondering if anyone knows what chain goes on a 76 900 ? i put a gsxr wheel on it and the chain wont fit does anyone know the size of the kz and the size of the gsxr?? thanks
1976 KZ 900 PRO STREET 1977 kz1000 dragbike project
- Mcdroid
- Gone Kwackers
Re: CHAIN
23 Aug 2010 05:47
So, what doesn't fit? Too long, too short, too narrow, or too wide?
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- PLUMMEN
Re: CHAIN
23 Aug 2010 05:47
the 900 came with a 630 origionally,gsxr probably has a 530 sprocket
- JEFFG1
Re: CHAIN
23 Aug 2010 06:17
well i have the stock sprocket on the motor and the gsxr sprocket on the wheel which is a gsxr also . the one on the wheel the teeth are to far apart chain wont fit . it looks like the sprocket off the old kz wheel wont fit on the gsxr wheel. wondering if i should change the motor sprocket to match the wheel and buy a chain to fit but didnt know what chain to use
Re: CHAIN
23 Aug 2010 06:26
JEFFG1 wrote:
Would have thought the stock 630 KZ900 front sprocket would have wider spaced teeth than the 530 GSXR wheel sprocket.
- DoubleDub
Re: CHAIN
23 Aug 2010 09:24
630/530/etc info here:
www.z1enterprises.com/reference/chaintypesize.aspx
- donthekawguy
Re: CHAIN
23 Aug 2010 17:08
The gsxr wheel might even have a 520 sprocket on it depending on the year. take the wheel to a bike shop and make sure. If its a 530 you can get a 530 sprocket for the kz at Z1E.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- timebomb33
Re: CHAIN
23 Aug 2010 17:17
or it may even have the oddball 532 sized chain the best thing you can do is get right front sprocket in 530 and get the right rear in 530 as well also what is your spacing like you may need to go with an offset sprocket go to the jt sprocket web site to figure out your proper sizing and also what sprockets are available. measure center to center on the sprocket teeth if they are 1/2" apart then its 50 series chain if its 3/4" apart then its 60 series chain then measure the width of the sprocket if it's 3/8 thick its 530 or 630 if it's 1/4" thick then its 520 chain
I THINK MY POWERBAND BROKE
- JEFFG1
Re: CHAIN
23 Aug 2010 18:11
YOU GUYS ARE ON IT:P I ALOT OF GOOD INFO THANKS I GUESS I COULD TELL YOU WHAT I AM DOING I PICKED UP A 76 900 I TRADED FOR A GOLF CART AND IAM PUTTING A D&G CHASSIS 7" OVER SWINGARM ON WITH 6" GSXR WHEEL WITH 190 TIRE. I WANTED TO PUT A 200 ON IT BUT I MITE HAVE FRAME PROBLEMS WITH THE CHAIN . NOT REAL SURE ABOUT OFFSET ON SPROCKET I HEARD 3/8 IS ALL YOU CAN DO WITHOUT HITTING THE CHAIN ON THE FRAME WHERE THE SWINGARM CONNECTS??
- langbein
Re: CHAIN
25 Aug 2010 21:18
Ok so here goes my first post ...
Am replacing a 30 year old chain on a KZ1000 CSR M1
Currently 630 chain, front sprocket 15, rear 39, ratio 2.60
Mechanic is suggesting chain 530, front 17, rear 46, ratio 2.70
BUT all the calculators that I have found from reading many posts here suggest chain 530, front 18, rear 47 to maintain 2.61 ratio.
IF I go with adjusted ratio as suggested by my mechanic
what can I expect?
He is saying that the Xring DID chain is superior to the oring chain and that with weight reduction I can expect 5hp increase.
Also says that ratio change will give me more top end speed and more revs per gear.
I really hope that he isn't a member on this site and readin this !!! - I'm just looking for a few other opinions prior to going with his suggestion. Love my ride and am looking to keep it as original as possible while making it smoother and running well.
Thanks in advance for your opinions.
what can I expect?
1981 KZ1000 CSR M1
- MFolks
Re: CHAIN
25 Aug 2010 22:10
An 18 tooth front(engine sprocket) will not fit if it's a 630, but it should fit if you change to 530(I'd check with somebody in the know before ordering chain and sprockets).
Re: CHAIN
25 Aug 2010 23:16
langbein wrote:
Would use oem sprocket sizes and x-ring 630 from Z1E.
...Am replacing a 30 year old chain on a KZ1000 CSR M1. Currently 630 chain, front sprocket 15, rear 39, ratio 2.60. Mechanic is suggesting [blah, blah, blah] and saying [blah, blah, blah]. Love my ride and am looking to keep it as original as possible while making it smoother and running well.....
