Hand brake leaking
  • Omaha Rider
  • Omaha Rider's Avatar Topic Author
Hand brake leaking
20 Aug 2010 10:00
#392485
There is brake fluid coming out of my handbrake lever. Do I need to replace a seal or something? Is the hand brake sopposed to click when you pull on it? Mine does not. Help is greatly appreciated.
Thanks
1978 KZ650 SR D
  • Motor Head
  • Motor Head's Avatar
Re: Hand brake leaking
20 Aug 2010 10:11
#392490
A rebuild kit for the Master Cylinder will most likely fix it, hard to say until you look at the cylinder bore. If you don't have a brake hone most of the Auto parts stores will have a small 2 or 3 stone hone. It would be the right time to get a kit for the Caliper or Calipers depending if single or dual disc.
Z1 has a great price on rebuild kits, I just put 1 in from them and it is now great. The leaking fluid will damage most paints, and also other surfaces, be careful not to let it set on your paint.
  • Kawickrice
  • Kawickrice's Avatar
20 Aug 2010 10:48
#392502
If its dripping it will ruin the paint on the tank or any thing it touches for that matter. Sounds like its time for a rebuild
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • Omaha Rider
20 Aug 2010 11:56 - 20 Aug 2010 12:19
#392522
Will this work? I have a 78 kz650 D SR.
cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll...&itemid=380146719641
P.S. Is the brake lever sopposed to click when pulled?
1978 KZ650 SR D
Last edit: 20 Aug 2010 12:19 by Omaha Rider.
