axle stuck in wheel
  • 55fbomb
  • 55fbomb's Avatar Topic Author
axle stuck in wheel
18 Aug 2010 19:02
#392002
I have a problem with my KZ1000. the bike hasnt seen the road in 10 years and when i went to take off the rear wheel to replace the chain and check some stuff out, the wheel wouldnt come out of the bike. the spacers and caliper mount are coroded right on to the axle, i ended up getting it out by taking the back part of the axle blocks off and wiggling it back and forth and oiling it and after nearly an hour it came loose. i now have a rear wheel with the axle stuck in it, and i mean suck! i beat on the axle back and forth and sprayed oil on it until the block of wood i was using between the axle and hammer was pretty much gone. i have never had this happen to me before, any ideas? thanks.
1974 CB750
1975 CB750
197? CB750 mutt
1977 KZ1000
Re: axle stuck in wheel
18 Aug 2010 19:09
#392004
Soak it with Kroil for a couple days - it will loosen. Ed
  • MFolks
  • MFolks's Avatar
18 Aug 2010 19:16
#392006
Corrosion can pretty much lock things together. Penetrating oil followed by heat usually free's things up for disassembly.I'd try a propane torch or a heavy duty hair dryer.
Two brands I like are PB Blaster and Kroil for stuck together parts.
The bearings are probably toast by now, so www.goallballs.com should have new ones for you.
When re-assebly time comes around, put a thin coating of the silver Anti-seize on the axle as it will make removal much easier.
  • 55fbomb
18 Aug 2010 19:34
#392014
i have it soaked in PB Blaster now and am gonna go around with it again tomorrow. and yeah, i figured the wheel bearings are trash now so i gotta get those now too. Kroil is pretty expensive for my lol, thanks guys.
1974 CB750
1975 CB750
197? CB750 mutt
1977 KZ1000
  • JMKZHI
  • JMKZHI's Avatar
19 Aug 2010 05:08
#392076
Liquid Wrench penetrating lubricant is another good one & it's usually cheap.
It performed better than PBB in a test posted here on KZR.
LW has a number of good products & they're usually cheaper than others.
Unfortunately, for me anyway, I don't think they make their cycle chain lube any more. Three bucks for a big can & it was a good product.
PS: wd40 was the worst. I hate that stuff.
  • PLUMMEN
  • PLUMMEN's Avatar
19 Aug 2010 06:32
#392099
zep45
  • Kawickrice
  • Kawickrice's Avatar
19 Aug 2010 07:05
#392106
BFH......... Bigger fu@@in Hammer :) :) :) :)
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • bountyhunter
  • bountyhunter's Avatar
19 Aug 2010 14:48
#392195
There's a better one: get the DuPont Multi Purpose teflon spray lube at Lowes in the blue can. I think it is $5 for a giant can. Best chain lube I ever found. Goes on wet to penetrate in and then dries to a waxy film. Does not throw off or hold dirt. My new chain is showing zero wear using it (no stretch).
  • TexasKZ
  • TexasKZ's Avatar
19 Aug 2010 15:23
#392208
+1
  • Joe Fabulous
  • Joe Fabulous's Avatar
19 Aug 2010 16:44
#392237
Soak in penetrating oil......get the gas bottles fired up.......massive hammer against a block of wood. Then nice new shiney wheel bearings!
2004 Harley Davidson Softail
1981 Z1000 Chop
1982 KZ1100 A2
XS 650 Plunger Chop (in bits)
  • 55fbomb
19 Aug 2010 17:26
#392250
I got it, had to keep spraying PB on it and beatin on it with a hammer, ended up using a punch to push it through, even after it broke free it still was stuck. now i need wheel bearings, when i put it together again so i could move it around, there was a loud thud when i tightened down the axle nut. i hope i can get this on the road before the snow flies. . .
1974 CB750
1975 CB750
197? CB750 mutt
1977 KZ1000
  • bountyhunter
19 Aug 2010 19:38 - 19 Aug 2010 19:40
#392294
Z1 carries most everything. If they don't have it, Old Bike Barn has a lot of KZ parts. If you have to order OEM from kawi, Bike Bandit and babbittsonline.com will get you a good discount on kawi parts./
Last edit: 19 Aug 2010 19:40 by bountyhunter.
