'02 KZ1000P- suspension mod ideas wanted
  • blipco
  • blipco's Avatar Topic Author
  • 2002 KZ1000P
10 Aug 2010 12:59 - 10 Aug 2010 13:05
#389921
I recently purchased a 2002 kz1000p with 11,000 miles. This bike has never seen police work. It is in excellent condition. I plan on making this my long distance tourer. I've noticed however that it's highway manners are less than stellar. I will eventually go up one tooth on the front sprocket to mellow out the rpm's but I'm looking for advice from anyone who might have any ideas as to how I might make this bike a more stable ride at say 75 - 80 mph. It seems to be all over the place while making quick lane changes and such. I know it's not a sport bike, just looking for a solid ride.
So far I've replaced the OEM run flats with Bridgestone Spitfire tires. 110/90 front and a 130/90 rear. Thanks.
Last edit: 10 Aug 2010 13:05 by blipco.
  • porchev914
  • porchev914's Avatar
Re: '02 KZ1000P- suspension mod ideas wanted
11 Aug 2010 00:11
#390035
How wild are you looking to get with your mods?
FRANKEN Z!
  • blipco
  • 2002 KZ1000P
11 Aug 2010 13:37
#390139
I want to keep the bike as stock as possible but I want to get rid of that "wet bag" handling. I'm hoping some kind of fork brace will help though I fear it is the frame that is the culprit. I will consider any suggestions I get.
  • MFolks
  • MFolks's Avatar
11 Aug 2010 13:56
#390146
  • blipco
  • 2002 KZ1000P
11 Aug 2010 19:30
#390214
I've done business with Phil at Aftershocks. Good place.
  • testarossa
  • testarossa's Avatar
11 Aug 2010 19:39
#390218
I though that the police bikes had some of the best frame bracing from the factory. I would start by replacing the rear shocks and rebuilding the front fork with new springs, oil and seals. It would be worth your time to check the steering neck bearings. They could be loose and need adjustment or just plain wore out. Also check that the tires are properly inflated.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
11 Aug 2010 20:49 - 11 Aug 2010 20:51
#390243
Brace everything up.
Stiffen your new setup.
Spitfires are ... ok. kinda sloppy.
RUBBER:
AVON VP2 Sport, nice price/performance.
GL!
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 11 Aug 2010 20:51 by TeK9iNe.
  • blipco
  • 2002 KZ1000P
15 Dec 2015 04:59
#703172
Here is an update.
My brother is now riding my KZP due to a bad knee, he can't bend it so his sport bike had to go.
Anyways, he bought different profile tires, Pirellis I believe, and that tightened things up.
But the big thing, he found a guy that has a few fork braces that fit the police model. If anybody is interested, email me at blipco@yahoo.com (to make sure I get it)
and I will ask my brother where he found them. Be warned though, he doesn't keep paperwork and he usually forgets where he puts his memory. LOL
  • 80B4
  • 80B4's Avatar
15 Dec 2015 05:42
#703173
I have had good results setting the static sag on my vintage bikes to about 30mm front and 25mm rear. Doing this makes the handeling very stable and at the same time takes the slop out of the handeling.
1980B4 1000
1978 Z1R
1978 B3 750
  • blipco
  • 2002 KZ1000P
15 Dec 2015 13:10 - 15 Dec 2015 13:13
#703215
Come to think of it, my sag was set for my weight at 185. We never reset the sag for my "little" brother who weighs in at about 240 (claimed weight mind you). So that is yet another step to be taken.
I can say though, the sportier tires and fork brace have definitely helped.
And keep in mind, when you jump off a modern sportbike to a vintage motorcycle you are in for a rude awakening. (But a good awakening).
Last edit: 15 Dec 2015 13:13 by blipco.
