low speed wobble
  • gotakz
  • gotakz's Avatar Topic Author
low speed wobble
06 Aug 2010 13:02
#388705
Hi everyone, I have a 76 kz900....What would cause a low speed wobble.. at at under 30 let go of the handlebars and it will start to wobble.......thanks
1976 Kz900-A4
Had a 1985 Gpz750
  • mjg15
  • mjg15's Avatar
Re: low speed wobble
06 Aug 2010 13:08
#388707
Loose bearings (steering head or wheel)
Bent wheel, defective/worn tire. Low pressure
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
06 Aug 2010 13:17
#388709
Like what was already posted, I would start with checking tire pressure, then putting the front end up and re-cheching the steering stem preload. While the wheel is up tape a pencil to the fork leg and check for trueness of the rim.
Your fork height will have an effect of stabiliy too.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • TerryK
  • TerryK's Avatar
06 Aug 2010 14:52 - 06 Aug 2010 15:02
#388737
I almost guarantee it's worn out steering head ball bearings. The balls wear into the races and at low speeds the balls want to roll in and out of these little recesses.
To find out if this is the problem, put the bike on the center stand and have someone hold the rear tire on the ground so the front wheel is unsupported. Turn the bars slowly back and forth and you should feel the bearings "bumping" as you do.
Take the front end apart and throw the stock bearings and races into the bush as far as you can throw them then replace them with a tapered roller bearing kit.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Last edit: 06 Aug 2010 15:02 by TerryK.
  • Motor Head
  • Motor Head's Avatar
06 Aug 2010 14:54
#388738
Its probably a good Idea to also check the swing arm bushing/ bearings as this can cause handling issues as well.
  • tinlizzie37
  • tinlizzie37's Avatar
06 Aug 2010 14:57
#388739
I'm in agreement with Terry K. My KZ 650 wobbled at about 40 mph. I took the front end apart and found the lower balls were all rusty. I replaced them with the tapered bearings and all is well. No wobble even up to 100 mph.Bob
Bob KZ 650 E1, En 450
  • TerryK
  • TerryK's Avatar
06 Aug 2010 15:01
#388740
A lot of those other problems usually happen at higher speeds. The ball bearing thing usually happens at low speeds.....although really bad cases will show up at any speed.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
  • muddy1
  • muddy1's Avatar
  • 1980 Kz1000 LTD B4
06 Aug 2010 16:32
#388751
I'll go with low tire pressure, my 750 Ninja did that to me! At high speed my wobble was due to a cracked frame on my 73 Z1.....
1970 SL-70
1972 CB 750
1976 YZ 125
1976 KZ400
1979 KZ400 LTD
1980 KZ1000 LTD B4
1984 YZ 490
1989 750 Ninja
  • PLUMMEN
  • PLUMMEN's Avatar
06 Aug 2010 17:44
#388784
id suggest the omr steering head bearing mod myself B)
06 Aug 2010 20:01
#388826
Steering stem bearings; irregularly worn tire(s); swing arm bushings.
