GS 1100 Swingarm & Suspension
- Kyle_w11
05 Aug 2010 13:01
I recently came across a bike that has been sitting for 27 years and am trying to get it up and running. Here's the original thread.
kzrider.com/index.php?option=com_kunena&...w&catid=11&id=295914
As a side note, i'm looking to remedy the situation that the suspension is in. See Below:
i'm assuming I should just find a set of shocks with a clevis mount. I would like some more suggestions though!
Cheers,
Kyle
Cheers,
Kyle
1976 KZ 900 A4 with 1974 Z1 Big Bore Engine - 10,000 mi.
- Jack
Re: GS 1100 Swingarm & Suspension
05 Aug 2010 13:24
We used GS 1100 shocks and fabbed spacers for the top mounts to install on my MKll frame.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- mjg15
05 Aug 2010 13:53 - 05 Aug 2010 14:48
....well since I started the trouble about this in the other thread I will offer a suggestion. One of my 550's came to me with an aftermarket swingarm that had clevis mounts. The previous owner had removed the eye mounts that were welded on the shocks and replaced them with a clevis type mount. It was a neat and clean job that was barely noticeable. the shocks in your pic are some brand of aftermarket shocks that would be well worth fabbing to fit the GS arm. You can take them apart, do the mod and rebuild and repaint them while you are at it.
Heres a picture. Never mind the rust....it cleaned up with some scotchbrite. The black shocks that you have would be much easier to refinish than my chrome Konis.
(I recently sold this pair of shocks on Ebay)
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
Last edit: 05 Aug 2010 14:48 by mjg15.
- mjg15
05 Aug 2010 14:00 - 05 Aug 2010 14:03
Heres a better picture (after I cleaned up the rust). Looks like they used a piece of off the rack steel stock.
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
Last edit: 05 Aug 2010 14:03 by mjg15.
- otakar
05 Aug 2010 15:17 - 05 Aug 2010 15:19
Kyle_w11 wrote:
Very Dangerous.
You can use GS1100 shocks which will lower the rear end a bit or you can use Gold Wing shocks which will raise the rear about 1/2". I use the Gold Wing shocks on my bike.
Cheers,
Kyle
Very Dangerous.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 05 Aug 2010 15:19 by otakar.
- otakar
05 Aug 2010 15:21
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- hocbj23
05 Aug 2010 15:30
The stock Suzuki GS shocks work just fine.bj
- otakar
05 Aug 2010 18:12
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Kyle_w11
05 Aug 2010 18:53
those all look good! I will likely try to find some shocks that will fit. I don't have the tools to do the modifications to the current ones.
- donthekawguy
05 Aug 2010 19:14
I used goldwing shocks on mine also.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- mjg15
05 Aug 2010 20:47 - 05 Aug 2010 20:50
Shocks for '79-83 CB750F, 900 and 1100's should work also. I replaced the modified Konis above w/Ohlins from a CB900F
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
Last edit: 05 Aug 2010 20:50 by mjg15.
