76 kz 900 swingarm swap
05 Aug 2010 11:17 #388381 by Reaper40
76 kz 900 swingarm swap was created by Reaper40
trying to find out what swingarms are compatablewith my 76 900. looking to go single shock
05 Aug 2010 19:26 #388501 by donthekawguy
Replied by donthekawguy on topic 76 kz 900 swingarm swap
Any arm where the wheel is centered in the arm should work. Getting the geometry for the shock mount is the tricky part but it can be done. I would use an arm off of a bigger bike due to the engineering involved for a heavier bike. I wouldn't use an arm off of a modern 500 for an old 900.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
05 Aug 2010 20:08 - 05 Aug 2010 20:10 #388522 by TerryK
Replied by TerryK on topic 76 kz 900 swingarm swap
Early GSXR arms work well, as do late model GSXR1000 and Hyabusa. Below is my 77' KZ1000 with an 87 GSXR750 swingarm. Although I went with the dual shocks, I could have kept the single shock setup.
It's about 3 inches longer and fits right in between the frame with no mods. You'll need to have a machinist make you some inserts to press into the GSXR inner bearing sleeves to reduce them to fit the stock pivot bolt. Axle diameter is the same but you'll need a longer bolt, either the Gixxer one of call your machinist again like I did.
Off course you'll need a longer chain and you have to deal with the rear brake (I modded the gixer one....but don't go there!!).
I run a 150 rear tire on a WM6 (3in) rim and it works great.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Last edit: 05 Aug 2010 20:10 by TerryK.
