Z1 Master Cyl. Rebuild
- GregZ
03 Aug 2010 04:48
Has anyone rebuilt there front master cyl. on there Z1.
Is it difficult do I need any special tools etc.
- Kidkawie
- I bleed premix
Re: Z1 Master Cyl. Rebuild
03 Aug 2010 05:08
My FSM shows a special tool that looks like a pick, another one that looks like a deep socket with a handle and a set of snap-ring pliers.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- MDZ1rider
03 Aug 2010 07:54
You'll need a set of long nose snap-ring pliers to get the internal plunger C clip out. Look inside the hole where the banjo bolt threads in. Z1 Enterprises carries a Motion Pro tool specifically designed for this.
- Jeff.Saunders
03 Aug 2010 07:59
The deep reach circlip pliers are a must. Depending on the state of the snap-ring clip, you may want to soak the snap-ring in PB Blaster or similar to help release the snap-ring.
What you don't want to do is beak the tips off the snap-ring - I've been there and done that - it's then VERY difficult to remove the snap-ring.
Most of the general automotive type deep reach circlip pliers will NOT reach deep enough. Even the ones we sell have to be attacked with a grinder to allow them to go down deep enough into the 1/2" bore.
www.z1enterprises.com
Z1 Ent on Facebook,
- GregZ
03 Aug 2010 09:12 - 03 Aug 2010 09:15
well I have it soaking in blaster just in case. My snap ring pliers are way too short.
Fleabay has these ,nice but a little salty.I'll figure something out
cgi.ebay.com/ebaymotors/HONDA-CB350-CB36...fPartsQ5fAccessories
I'll order the pliers from jeff,little cheaper there
Last edit: 03 Aug 2010 09:15 by GregZ.
- DoubleDub
03 Aug 2010 09:12
I used the kit - works great. I did have to buy the deep reach snap ring pliers from Z1E also. I didn't have to grind them, just had to be very creative when positioning them. But I'm sure grinding would have made it easier.
