Aluminum Swingarm 6-8" over
  • Awamori
  • Awamori's Avatar Topic Author
  • '76 KZ900 LTD
31 Jul 2010 15:20 - 31 Jul 2010 15:23
#387283
Hello,
This is my first post. I just bought a '76 KZ900 LTD. I have been searching all around google and KZ forums, but cant seem to find anyone selling a 6-8" extended aluminum swingarm.. (for under 1000 dollars anyway).
Is anyone still making these?
Also, my bike is missing the keys. Has anyone ever successfully picked the lock on the gas cap?
Some pics:
'76 KZ900 LTD
Last edit: 31 Jul 2010 15:23 by Awamori.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: Aluminum Swingarm 6-8" over
31 Jul 2010 17:15
#387300
Can't help you on the swingarm but any Kawasaki key will open the lock...there are no tumblers inside.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • Old Man Rock
  • Old Man Rock's Avatar
31 Jul 2010 17:20
#387302
Uhm... Are you ever planning to turn this bike on a ride or is this going to be a drag bike?
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • Awamori
  • '76 KZ900 LTD
31 Jul 2010 18:21
#387318
Not going to be a drag bike. I just like the way the KZs look with a extended rear. I may not go as long as 6-8", but at least 4 or 5".
Thanks for the tip on the gas cap.
'76 KZ900 LTD
  • racer54
  • racer54's Avatar
31 Jul 2010 19:09
#387324
Any aluminum arm is going to cost. At least an aftermarket one anyway. An arm made from chromoly is a bit cheaper. I've even seen them in mild steel. A few places make chromoly arms but not sure of some of the prices. You'd have to call and get a quote. Here are a few places...
www.fastlaneracecars.com
www.fbrshop.com
www.dgchassis.net
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
31 Jul 2010 19:10
#387325
Nice 900LTD!
I can cut you a key if you know the key code #.
It will probably be stamped next to the key hole on either the ignition or seat lock.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
  • PLUMMEN
  • PLUMMEN's Avatar
31 Jul 2010 19:17
#387327
going much more than 2-3" over tends to take too much weight off a small back tire causing a lack of traction in my experiance anyway,which means youre stuck either going with a really sticky tire or a really wide one to make up for it.
  • Awamori
  • '76 KZ900 LTD
31 Jul 2010 19:22
#387328
racer54, thanks for the links. I'm sure one of those companies have what I'm looking for.
rstnick, I'll let you know on the key, thanks.
Plummen, something I definately need to consider. I'm new to motorcycles in general. Maybe it will be better just to go with the GS1100 conversion. That is about 2-3" right?
'76 KZ900 LTD
  • PLUMMEN
  • PLUMMEN's Avatar
31 Jul 2010 19:27
#387330
gs arm is 1 1/2-2" depending on who you ask B)
  • Awamori
  • '76 KZ900 LTD
31 Jul 2010 19:34 - 31 Jul 2010 19:51
#387333
Not much for all the effort. I'll probably go 3-4" and jump up to a 160 or 170mm tire.
'76 KZ900 LTD
Last edit: 31 Jul 2010 19:51 by Awamori.
  • TerryK
  • TerryK's Avatar
01 Aug 2010 18:56 - 01 Aug 2010 19:05
#387540
I used a mid 80s GSXR swing arm on my 1000. It's about 3 inches longer and fits right in between the frame with no mods. You'll need to have a machinist make you some inserts to press into the GSXR inner bearing sleeves to reduce them to fit the stock pivot bolt. Axle diameter is the same but you'll need a longer bolt, either the Gixxer one of call your machinist again like I did. :P Cut off the single shock mount, weld on some duel shock mounts and Bob's your uncle!
Off course you'll need a longer chain and you have to deal with the rear brake (I modded the gixer one....but don't go there!!).
I run a 150 rear tire on a WM6 (3in) rim and it works great.
a.imageshack.us/img828/7597/dsc00653l.jpg
a.imageshack.us/img525/2719/dsc00652h.jpg
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Last edit: 01 Aug 2010 19:05 by TerryK.
  • PLUMMEN
  • PLUMMEN's Avatar
01 Aug 2010 19:09
#387546
not much effort at all actually,you need to shim about 3/16" on either side of pivot tube and use suzuki shocks.
you can run a 150-160 tire on a gs1100 swingarm pretty easily,wider than that just causes lots of chain alignment problems.
another good thing about the shorter gs1100 arm is the longer your wheelbase gets,the harder it is to get around in tight places
