Front of engine mounting bolt needed
  • thadley55
  • thadley55's Avatar Topic Author
  • TWO WEEKS!!!(Money Pit the movie)
31 Jul 2010 09:42
#387236
I have a 76 KZ900 the previous owner broke off the nut on the long bolt that mounts at the front of the engine. I called Z1 Ent. and they told me they don't have them and can only get the kits which are very pricey. They told me to check with u guys to see if anyone would have an extra one and would be willing to let go of it. I am not looking for a handout I will pay u for it. If any of u know where to get one elsewhere plz let me know.
Thanx,
1975 XL125 Honda first bike
1993? VTR 250 Honda gone
1983 LTD 440 Yammy gone
1988 CBR 600 Honda gladly gone!!
1976 KZ900 daily driver
  • School Teacher
  • School Teacher's Avatar
Re: Front of engine mounting bolt needed
31 Jul 2010 10:18
#387240
where are you located?
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
31 Jul 2010 13:03 - 01 Aug 2010 02:41
#387264
It's easy enough to make one.
Get an inexpensive steel dowel rod from the local hardware store, of appropriate diameter to cut threads of oem size.
The rod will likely be measured in "inches" (fraction of an inch) and I don't recall the exact diameter, but one of the common sizes is perfect to cut the metric threads.
Cut rod to length, and thread both ends, and use nuts on both ends.
This is also a handy way to fashion a slightly longer than stock bolt when needed for whatever reason, such as attaching certain accessory fitments (some styles of cruise pegs, for instance, or a thicker mounting bracket).
Of course, a fully pre-threaded steel rod is also available (likely in a fractional inch size) which could be cut to length and fitted, if don't mind exposed threads visible across front of engine. And don't mind using non-metric at this location.
Good Fortune! :)
Last edit: 01 Aug 2010 02:41 by Patton.
  • thadley55
01 Aug 2010 01:38
#387362
School Teacher I am in Red Oak TX. Patton I thought about all-thread is that strong enough?
01 Aug 2010 02:36 - 01 Aug 2010 02:37
#387364
The long front bolt sandwiches or clamps the motor between the down tubes, without separately affixing each side of the motor to an individual down tube.
Some folks believe that using a separate shorter bolt on each side of the motor, whereby the motor is supposedly more tightly held to the down tubes, enhances frame stability and rigidity.
I've tried it that way, but didn't notice the difference (but didn't road race it either).
May entail some modification of the bolt heads or nuts to fit inside the channel on motor side.
To answer the question, I believe all-thread would be okay, just harder to keep clean.
Don't know if all-thread is available in metric. But prefer staying with the same thread type on a vehicle when possible.
Good Fortune! :)
Last edit: 01 Aug 2010 02:37 by Patton.
  • dshelly
  • dshelly's Avatar
01 Aug 2010 06:38
#387373
I have one of those. If you still need it send me a PM and I'll hook U up.
dshelly
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
  • JMKZHI
  • JMKZHI's Avatar
01 Aug 2010 07:11
#387379
Patton wrote:
... The rod will likely be measured in "inches" (fraction of an inch) and I don't recall the exact diameter, but one of the common sizes is perfect to cut the metric threads...
Probably 3/8" which is almost the same size as 10mm.
  • thadley55
01 Aug 2010 20:15
#387566
Thanks for the offer dshelly but I think I will just use the all-thread it's just a daily driver and fairly stock so I don't put a lot of torque on it. U can save the bolt for someone who needs it more.
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
02 Aug 2010 05:35 - 02 Aug 2010 05:37
#387599
FWIW, my Z1 has the 2 piece case guards that utilize a threaded rod instead of the OEM bolt. It's not all thread, but a steel rod with threads on either end and two locknuts.
Maybe you could contact the manufacturer and ask for a replacement rod?
cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll...&itemid=200498131566
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
Last edit: 02 Aug 2010 05:37 by Kidkawie.
