Anybody try these?
  • Lazyman06
  • Lazyman06's Avatar Topic Author
Anybody try these?
28 Jul 2010 18:07 - 28 Jul 2010 18:08
#386662
cgi.ebay.com/ebaymotors/FRONT-BRAKE-MAST...ries#ht_24822wt_1027
thought about getting one of these, but didn't know how good they are. I took mine apart as much as I could and they look terrible.
1979 KZ1000 MK II frame
1980 KZ1000 C3 police engine
Last edit: 28 Jul 2010 18:08 by Lazyman06.
  • otakar
  • otakar's Avatar
Re: Anybody try these?
28 Jul 2010 19:56 - 28 Jul 2010 20:02
#386691
That's the same kind I mounted on mu GPz1150. It's not the greatest but it works just fine. Sometimes (not all the time) it feels a little mushy. But I have had it mounted for three years now and i'm still alive. Matter of fact, I bought it from the same guy.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 28 Jul 2010 20:02 by otakar.
  • Lazyman06
29 Jul 2010 05:02
#386734
sweet thanks otakar. might go ahead and pick up one of these then.
  • otakar
  • otakar's Avatar
29 Jul 2010 06:17
#386741
I know he has none listed, but I wonder if he has rebuild kits for those. I use DOT 4 fluid in mine. Make sure you bleed the system perfectly and allow the piston to swell. For the first day I had it on the bike it was unusable because it did not pump. By the next day the piston sealed and it worked.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • cobura
  • cobura's Avatar
  • forever 2 wheels
29 Jul 2010 09:17
#386777
stick with brembo B)
1979 KZ650B3
  • Lazyman06
29 Jul 2010 15:46
#386866
ummm cobura....where's the master cylinder
  • ready2ryde1985
  • ready2ryde1985's Avatar
  • got to love these kzs
29 Jul 2010 15:53
#386870
That bremo is nice for bout 100 bucks then to put the resivor on thoes run about 25 for plastic and 50 to 150 for the nice milled aluminum ones price to preformance the cheep one will do fine.
If you upgrade to the brembo def get new seals thoes are capable of alot more presure than the stock and no one wants to blow break seals when trying to stop hard in an emergency!!
84 kz 700 a1
82 kz550 ltd
