WHEEL SWAP
- JEFFG1
WHEEL SWAP
28 Jul 2010 06:59
I HAVE A 76 900 I WANT TO SWAP WHEELS ON .. I BOUGHT 1995 GSXR 750 WHEELS AND A D & G SWINGARM WITH 900 AXEL I WAS WONDERING THE WHEEL BEARING ON THE GSXR WHEEL IS ALOT BIGGER THAN THE AXEL I HAVENT PULLED THE STOCK WHEEL IT IS ON THE BIKE AND I STILL HAVE SOME SUMMER LEFT SO THIS WILL BE A WINTER PROJECT I SEE ALOT OF THESE SWAPS ON HERE DO YOU HAVE TO CHANGE BEARINGS OR DOES THE SPACERS ON THE 900 WHEEL TAKE UP THE SLACK?? THANKS GUYS
1976 KZ 900 PRO STREET 1977 kz1000 dragbike project
- otakar
Re: WHEEL SWAP
28 Jul 2010 07:05 - 28 Jul 2010 07:06
Hello and welcome. First of all, please turn off your CAPs-lock. It makes your post hard to read. Second of all, yes you will have to change the bearings and a lot more. Such as converting your drum brake KZ900 to a disc brake with a new mastercylinder and all the little things to go with it. You might also run into some mods for your front end also.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 28 Jul 2010 07:06 by otakar.
- JEFFG1
Re: WHEEL SWAP
28 Jul 2010 09:13
thanks for the info i already have ltd wheels on it with disk brake i was wondering if there is a chart or a place i could find replacement bearings for this swap ??
