KZ1100 swing arm removal
  • KevZ
  • KevZ's Avatar Topic Author
11 Apr 2006 10:05
#38618
Does anybody have a suggestion for removing the pivot shaft from the swingarm? Mine seems to be welded, and I want to paint the frame and replace those bearings......
  • wireman
  • wireman's Avatar
Re: KZ1100 swing arm removal
11 Apr 2006 10:15
#38620
put a breaker bar on the bolt after you remove the nut if the bolt will spin find a piece of 1/2-5/8" rod and use it to pound the bolt out.do not use 1/2" drive extension the square end will get stuck in swingarm bushing,dont ask me how i know!:whistle: :woohoo: goodluck,happy wrenching!
