USD Forks that allow use of stock wheels
- KawiConvert
23 Jul 2010 10:18
As the title says, I am looking to see if anyone has found USD forks that will take the stock wheel spacing. I can turn or mill parts needed to do this. Really looking to see if such a thing exists. Also if the stock length will be kept.
Thanks,
KC
Thanks,
KC
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
- zed1015
Re: USD Forks that allow use of stock wheels
23 Jul 2010 10:32 - 23 Jul 2010 10:33
If these are for the z650 then zx9r-b usd's are about the same length. also Yam yzf750ru.
Why do you want std wheel spacing ?.
If you've got a lathe etc then there will be no problem knocking up some suitable wheel spacers.
Last edit: 23 Jul 2010 10:33 by zed1015.
23 Jul 2010 10:46
Even so, be prepared for all sorts of headaches getting the brake caliper(s) to line up with the rotor(s).
- KawiConvert
23 Jul 2010 11:02
I'd like to keep the stock rotors due to the time I put in them. I'd like to upgrade the forks to improve the handling a bit. I also don't want to upgrade the front wheel because then I would have to swap out the back wheel and I'm not up to doing a swingarm swap.
23 Jul 2010 11:20
The simplest solution might be to install some new springs from Progressive Suspension, a fork brace and some new seals and oil. If they make one for your bike, a Gold Valve would be the bees knees.
23 Jul 2010 11:26 - 23 Jul 2010 11:27
Race Tech goodies---
Attachment FORK_PRODUCTS.txt not found
Last edit: 23 Jul 2010 11:27 by TexasKZ.
23 Jul 2010 11:28
Ok, that didn't work out so well, but Race Tech has goodies for your model that will make a difference.
- Mark Wing
24 Jul 2010 13:45
I have a 92 ZX7 USD fork with a 18 inch police front wheel. I used a thin spacer for the discs and some sleeves on the axle nuts.
Mark
Mark
Yorba Linda Cal.
Yorba Linda Cal.
