Swing arm help
  • Brown Bear
  • Brown Bear's Avatar Topic Author
Swing arm help
21 Jul 2010 16:50 - 21 Jul 2010 17:18
#384436
i have a Z400j 4cyl.
im converting it into a bobber, so far so good, its gona be a mono shock, but im not sure what swingarms i can use etc?
other than the standars and weld and alter it into a mono which isnt too hard but if i can get one already to go then even better. lol.
dont spose any of you people can help me. thank you
oh and yes i tried two shocks side by side but that dindt work. looked good tho i must say
found these so far
cgi.ebay.co.uk/yamaha-rd350-lc-4lo-80-82...&hash=item255c081464
cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem...geName=STRK:MEWAX:IT
Last edit: 21 Jul 2010 17:18 by Brown Bear.
  • porchev914
  • porchev914's Avatar
Re: Swing arm help
23 Jul 2010 11:31
#384961
I have no knowledge of the 400 frames, but if you're going to go to the trouble of a monoshock set up, you might as well go with a newer aluminum swingarm. One possible stumbling block will be whether or not you need an offset sprocket, and if anyone makes on for the 400...
FRANKEN Z!
  • Brown Bear
Re: Swing arm help
25 Jul 2010 09:15
#385526
the fram is pretty much the same as the 500/550 i belive or one of the bigger models
  • porchev914
Re: Swing arm help
25 Jul 2010 09:28 - 25 Jul 2010 09:29
#385533
What's the inside frame width at Tue swingarm pivot? Kz900-1000 frames are about 9.5" wide......
FRANKEN Z!
Last edit: 25 Jul 2010 09:29 by porchev914.
  • Brown Bear
Re: Swing arm help
25 Jul 2010 09:43
#385537
2 secs and i will go measure now. lol. also teh wheel space aswell
  • Brown Bear
Re: Swing arm help
25 Jul 2010 09:50
#385540
224mm at the pivot end, and 237mm at the wheel end
  • porchev914
Re: Swing arm help
25 Jul 2010 11:32
#385559
So that's approx 19mm narrower than the liter Kz. If you don't get any other responses here, cruise/search the projects section for swingarm widths on various builds. I can tell you a Triumph Speed Triple single sided swingarm is 285mm wide. Most guys here use swingarms that don't require frame widening. Perhaps the 650s have a narrower frame than the 900/1000s, and lots of guys mod them....Perhaps start looking there ;)
Adam
FRANKEN Z!
  • Brown Bear
Re: Swing arm help
27 Jul 2010 05:50
#386188
i have managed to get a GPZ550 swingarm, the unitrak one for £25 needs a good clean and refurb but im sure it can be altered to how i want it. hehe. will pay for that friday when i get paid. lol. then its just a monoshock needed..
