Newbie here and to riding.Looking for instruction
  • cudaeater
  • cudaeater's Avatar Topic Author
21 Jul 2010 15:26
#384416
Looking for help/tips/instructions on how to change sprockets and chain on my 82 KZ550ltd
  • MFolks
  • MFolks's Avatar
Re: Newbie here and to riding.Looking for instruction
21 Jul 2010 16:17
#384427
Have you ordered new sprockets and chain yet? Decided to go up one tooth on the engine sprocket and maybe down the same on the rear sprocket?
I use www.gearingcommander.com when figuring new sprocket and chain ratio's.
I don't know the specific operations for changing the engine(or countershaft sprocket) on your bike, but it's probably pretty close to what I have to do on my 82 GPz1100 B2.
1.I remove the foot shifter lever from the shaft,left foot peg assembly, and possibly the cover for the starter motor.
2.Keep the chain on the sprockets to aid in busting the nut holding the engine sprocket to the output shaft.
3.On some bikes, a special washer is used to secure the engine sprocket to the large nut.
4.It might require using a hammer and screw driver to bend the washer's locking tabs flat.
5.I have to use, (I believe a 22mm socket), with a long 1/2" breaker bar to loosen up the countershaft sprocket nut. The engine will have to be in gear for additional resistance to turning when loosening the engine sprocket nut(your bike is probably different).
6.If the chain is the "Endless" type, it will need to be cut off, either use a hacksaw or dremel too with a cutoff blade.Either that,or remove the swing arm and take the chain off this way(makes for an envolved job rmoving/reinstalling the swing arm/rear wheel/shocks).
7.There are many bikes on the road running drive chains with master links,as long as the chain is properly cared for by lubrication and tensioning, I see no problem
If you go up or down in sprocket sizes, you might luck out in not having to buy a longer chain.But keep this in mind if you find your new chain is too short.
  • TexasKZ
  • TexasKZ's Avatar
21 Jul 2010 16:57
#384441
loudhvx has a manual you can download from his signature line. Do a search for kz550 and you'll likely find a post from his with the link in it. Otherwise, pm him and I'm sure he'd be glad to share.
