Shaft to Chain??
- Kwschin
Shaft to Chain??
20 Jul 2010 13:19
Have a 1980 KZ1000 shaftie that is geared for 55 mph speeds, so it wails at 5 grand while doing 70 mph. Can the shaftie be converted to chain drive? It's got a 90 Degree drive bolted to the engine that goes to the shaft. Can't change gearing with the ring and pinion, so . . . . . ?????
- otakar
Re: Shaft to Chain??
20 Jul 2010 14:36
This subject has been covered before here. Yes it can be done It will require replacing much of the engine parts and transmission parts. Lot of work and money.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Kwschin
20 Jul 2010 15:16
Thanks for the info. Sorry to be a bother. "This subject has been covered before here." I'll do an archive search before I post another question.
- bountyhunter
20 Jul 2010 17:43
Fatter rear tire will raise the gear ratio a little.
- KZQ
- Administrator
20 Jul 2010 17:53
Kwschin wrote:
No problem Guy,
The Search function doesn't work very well.
Ask Away.
Bill
No problem Guy,
Ask Away.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- Kwschin
- RonKZ650
20 Jul 2010 19:21 - 20 Jul 2010 19:22
Stock KZ1000ST turns 3873rpm at 60mph which calculates to 4518 at 70 just for the record. No doubt someone put those 5:11 gears in over the years. :laugh: Maybe has the wrong tires. A low profile rear will goof up gearing.
Last edit: 20 Jul 2010 19:22 by RonKZ650.
- otakar
20 Jul 2010 19:56
Sorry, didn't mean to come across as a hard-ass. Here is a link to one of the posts, and i know there are more. There was one not too long ago.
kzrider.com/index.php?option=com_kunena&...d=2&id=194628#195005
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
