'78 LTD Rear Caliper Mystery???
- jtate1000
19 Jul 2010 08:48
On my '78 KZ1000 LTD, someone pointed out the rear caliper wasn't an LTD caliper. It basically looks like a front caliper, with a similar mounting bracket as what would be used for the "right" caliper. I went onto ebay and looked at some bikes for sale and there was a 1977 KZ1000 LTD with the same caliper as mine, but all the others were the caliper with the viewing window on top to see pad wear. Anyone familiar with this?
- jtate1000
Re: '78 LTD Rear Caliper Mystery???
19 Jul 2010 08:49
And by "right", I mean "correct", not right side...
- roy-b-boy-b
19 Jul 2010 15:01
I have a couple of those old calipers. They are cast iron and you have to remove them to install the brake pads.
I have one for a 650 also.
They are heavy and removing it will help your unsprung weight a lot.
Mine came off a "79" LTD. Roy
- Kawboy74
20 Jul 2010 20:26
My '78 LTD has the same caliper you have and also has to be removed to change the pads, not really a big deal. David
1974 Z1A As original as I could get it
'88 ZX750R braided lines, mostly original
KZ1000 project on the bench
Burlington,Ontario,Canada
- jtate1000
21 Jul 2010 08:38
I'm not worried about it, the setup is fine and I've already rebuilt it, etc... I'm just trying to figure out it it's original for that year, or a mod someone made somewhere down the line..
