Front brake pressure switch no longer working
  • toadson
  • toadson's Avatar Topic Author
17 Jul 2010 22:37
#383534
For about the past year my front brake will not trigger the brake light at all anymore, even if I pump up and hold the brakes. On my 79 KZ1000, it has a pressure switch threaded into the brake splitter, so one day I removed it and cleaned both the splitter and switch with brake parts cleaner. Some crud came out, and I hoped it would at least work afterwards. After getting everything bled, I still have no luck. I jumped the two wires that connect to the switch together and the brake light does come on, so it is not a wiring issue at least.
Is there a way to disassemble this switch or should I look for a new one? I tried searching the forum, but couldn't find much for some reason. I swear there have been plenty of topics on this that I have read in the past, but I can no longer find them. I actually wouldn't mind putting a newer master cylinder and brake handle setup that has the switch on the lever. Has anyone done this recently?
Thanks for any help, as usual!
79 KZ1000 LTD. Mikuni VM26 w/ accelerator pump. 4 into 1 header. Stock intake setup. GS1100 Swingarm, My swap thread: kzrider.com/index.php?option=com_kunena&...d=5&id=210872#210872
  • MFolks
  • MFolks's Avatar
Re: Front brake pressure switch no longer working
17 Jul 2010 22:42
#383537
  • steell
  • steell's Avatar
19 Jul 2010 15:22
#383872
I replaced the front master cylinder on my 79 750 twin with one from a 96 GPz1100 that had a mechanical brake light switch.
Same master cylinder is used on lot's of Kawasakis.
19 Jul 2010 17:54 - 19 Jul 2010 18:02
#383918
Z1E carries [click on each following link]:
Oem type pressure switch
switch cover
Z1E also carries an alternate style "banjo bolt" switch:
banjo bolt brake switch
another size banjo bolt switch
I would replace the oem switch, and be done with it. :cheer:
Good Fortune! :)
Last edit: 19 Jul 2010 18:02 by Patton.
  • toadson
19 Jul 2010 22:09
#384015
Thanks all, just ordered a new switch from Z1E, so I hope that will cure the problem!
  • ed spangler
  • ed spangler's Avatar
  • Tennessee Z
21 Jul 2010 16:02
#384423
I got one from Z1E, excellent value, less than $20
ED
Have 1975 Kawasaki Z1-B & 2003 Harley Davidson Heritage Softail Classic
Had Hondas, Harleys and many ,many Z Series Kaws both Std. & LTD's
  • toadson
24 Jul 2010 01:31
#385201
Installed the new switch, brake light worked before I even bled the brakes! Awesome! Thanks for the suggestions!
