Bar Snake: Reduces handlebar vibration
- Old Man Rock
13 Jul 2010 07:34
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- trianglelaguna
Re: Bar Snake: Reduces handlebar vibration
13 Jul 2010 08:43
no but it would work for sure...folks also fill em with sand....i like bar end wheights,they are all i need and they save in a garage tip over too...
you could make that with some thin wall tubing and then get some play sand when you and jimmy go to the playground....
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- Old Man Rock
13 Jul 2010 08:48
Saw the bar end types, would need to replace my grips...
I researched and found melted lead sinkers and tire weights, BB's, foam filled you name it....
None of which seamed truly the manner to go with and then I found this product....
Seems like ti work in concept anyways... maybe not remove all vibrations but if can reduce would be nice on the old fingers not to mention the havoc it's playing on my mirrors.... :S
I found a local source, under $30 so might give it a try and I'll report my findings/results....
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- hocbj23
13 Jul 2010 11:04
OMR--have u tried shorter mirror stems?I couldnt see squat in my mirrors because of the vibration "halo",so I found a set of "original" Kaw mirrors with 3 inch shafts.Voila-much better rear vision.I have an extra set if u would like to try them.bj
- Old Man Rock
13 Jul 2010 11:14
Much appreciated but I'm not running Kawi brake or clutch units so no thread in the bar mirror clamps...
My mirrors are fairly short at 5", convex mirrors and they work fairly well for the most part... Since my hands tingle after awhile and for the fact the CR carb springs are pretty stout, throttle hand especially goes numb after 30 minutes or so...
Not so bad for I have a throttle lock installed, keep present speed and shake her out a little...
Always looking for new concepts/toys to add to the collection of goodies....
Thanks,
OMR
Thanks,
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- taildragger1197
13 Jul 2010 12:09
Have you ever tried
grab on
grips?
Union City, Tennessee
1979 KZ1000 LTD B3
1979 KZ1000(1260)LTD S/G Pro ET
1993 ZX11 D1 Ninja
1979 KZ1000 LTD B3
1993 ZX11 D1 Ninja
- Old Man Rock
13 Jul 2010 12:16
I have foam grips now but not this name brand... Will look into them... thanks!
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
