Handlebar Oops!
- Fritto
Handlebar Oops!
12 Jul 2010 20:07
Hello Everyone,
I put another handlebar on the bike, looked like it would fit, but once I installed everything, it's pointing at about
40 degrees! Darnit! The brake like from the Master Cylinder is too short. Do any of you guys know of a kit to extend the banjo bolt fitting from the master cylinder to the front connection? Or is it easier (and cheaper) to just to get a longer hose and slap it on? What do you guys think? Yup, another Rookie move!:huh:
1981 KZ1100
Rookie Rider
Rookie Rider
- retterath
Re: Handlebar Oops!
12 Jul 2010 20:25
When I did the ninja clutch conversion, I went to the local logging supply shop and had them make me a new hose. Less than $20. A good auto parts place should be able too as well.
- Fritto
Re: Handlebar Oops!
12 Jul 2010 21:22
Z1E carries about any style and configuration of brake hose and fittings that might be needed.
