Whine from rear with new chain & sprockets
- fast_johnny
11 Jul 2010 12:16
Hi all,
I just changed the chain & sprockets on my '95 KZ1000P with original size parts and now I'm getting a whine from rear at speeds above 45mph. Applying the brake doesn't change noise. I'm concerned that maybe I tightened rear axle nut too tight. (no torque wrench, just tightened it to about 80-90 ft. lbs. by feel)
Or is this normal until new chain breaks in?
Thanks!
Thanks!
1977 KZ1000A1 1075cc, Kerker, Cavanaugh Head, RS34s
1995 KZ1000P
1995 KZ1000P
- mjg15
Re: Whine from rear with new chain & sprockets
11 Jul 2010 19:47
Check that you have adjusted the tension correctly. Maybe the spacer between the cush drive and wheel(inside the cush drive) fell out while you had things apart ?
New chains dont make break-in noise.
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
- MFolks
11 Jul 2010 20:06
Are the rear wheel bearings good? Original ones?
www.goallballs.com
has replacement bearings.
- otakar
11 Jul 2010 20:10
I have never used a torque wrench in my life on chain adjusting. Are you sure the sprockets are aligned properly to each other. If not, the chain will definitely wine against the rear sprocket.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- fast_johnny
12 Jul 2010 05:34
Thanks for the quick replies.
Bearings are good- only 10K miles. Spacers are in place. I'll check chain tension again as well as alignment.
1995 KZ1000P
1995 KZ1000P
- Old Man Rock
12 Jul 2010 05:58
Outside of alignment and chain slack clearance to spec.... You have applied chain lube right?
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
