A Question Concerning Collars/Spacers On My LTD
  • glennhudson
  • glennhudson's Avatar Topic Author
  • Art, science & people.
02 Jul 2010 00:00
#379595
hi.
i just had the rear wheel of my 1980 Kz1000 Ltd fitted with a new tire.
I think the collars/spacers of the rear axel did not come apart as my manual shows they should be upon reassembly.
Is it possible to assemble the components of the rear axel (collars/spacers) other than intended.
i mean, i got it together as *i believe* the manual shows and all is waiting to be torqued in, but i do not want to do so if it's not assembled correctly.
any input would be much appreciated.
-glenn
multiple media art * shoot & edit video * compose text & music
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: A Question Concerning Collars/Spacers On My LTD
02 Jul 2010 07:27
#379633
There is a specific sequence that must be followed when reassembling the rear wheel. However, the rear wheel assembly is one of those areas of older motorcycles that typically has a higher incidence of 'issues'. This is probably due to having had either a series of owners or having been to a number of different bike shops. Those internal spacers/collars tend to get misplaced/replaced when the wheel comes apart for tire changing. So, what you have may not match what should be there. if the bike handled fine before the tire change and you have reassembled it in reverse order, then you are probably safe.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
The following user(s) said Thank You: glennhudson
  • otakar
  • otakar's Avatar
02 Jul 2010 08:14
#379637
Go on Kawasaki.com and take a look at the parts diagram for your bike. It shows the parts in assembly order.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • glennhudson
02 Jul 2010 13:23
#379706
thank you both for the timely reply.
foolishly, i dropped the tire & did not see where the spacers fell from.
imma peep kaw.com for that info.
again, thank you!
  • glennhudson
05 Jul 2010 23:34 - 05 Jul 2010 23:35
#380530
well gentlemen...
i researched and found several diagrams online.
i picked one in particular www.cmsnl.com/kawasaki-1980-kz1000-b4-lt...partslist/61474.html to accompany the clymer manual that i have.
the clymers dialogue instructed a certain way to reassemble the rear axle, but it's accompanying diagram didnt match the instructions.
so i went ahead and interpreted the online diagram to a locked up rear end fail.
collar #4 sits pretty in the hub area of the sprocket.
i stuck the coupling (#13) on in the hub of the disc and on the left side of the caliper, and i stuck collar #23 on the right side of the caliper between the caliper & the swing arm.
after torquing to spec, the rear wheel wouldnt move.
coincidentally, #23 also sits deeper in the hub right under the coupling(#13)
is 23 sitting under 13 the proper set-up?
Last edit: 05 Jul 2010 23:35 by glennhudson.
