ZRX KYB's on 1980 Z1R
  • MADesign
  • MADesign's Avatar Topic Author
28 Jun 2010 11:10
#378753
Hey guys, long time no post. The Z1R project is finally back to life (had to put things on hold for a bit as I searched for parts and, oh yeah, had a baby!)
Have almost everything sorted, and about a full weekend's worth of reassembly prior to a test ride, but ran into a not-so-little hiccup with my plan to fit shocks from a ZRX onto the 'Ol Girl. The fitment is surprising perfect, but ran into a spacing issue on the drivetrain side. When mounted, the left shock is about 1/8" too close to the chain. The bottom 2 shock coils will rub.
I really want to keep the stock swingarm without cutting or welding. Is there any way I can get the bottom mount 'spread' to allow me to shim it?
Any suggestions or other ideas?
Thanks in advance - Mike
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: ZRX KYB's on 1980 Z1R
28 Jun 2010 12:36
#378769
can you mill some material off of the eye on the bottom of the shock?
  • MADesign
28 Jun 2010 14:17
#378781
hmm... Maybe mill the outside and shim the inside to space it away from the chain...?
May consider that.
  • 531blackbanshee
  • Vendor
  • Vendor
28 Jun 2010 14:23
#378782
thats what i'm talkin about.
  • mjg15
  • mjg15's Avatar
28 Jun 2010 14:31
#378784
520 chain may help also
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
  • MADesign
29 Jun 2010 06:33
#378946
I did think about a 530 or 520, but then I would have to deal with offset sprockets, gearing ratio calculations and whatnot, right?
  • 531blackbanshee
  • Vendor
  • Vendor
29 Jun 2010 06:39
#378947
shouldnt have to deal with offsets,but you would have to deal with re-calculating the gear ratio.i love my 520 conversion.
  • MADesign
29 Jun 2010 08:59
#378960
OK Leon,
Now I am interested, would you mind sharing some info on your conversion?
Sprockets used?
Gearing?
Chain of choice?
  • 531blackbanshee
  • Vendor
  • Vendor
29 Jun 2010 09:15
#378961
i did have to go with an offset countershaft sprocket because i am running a 190mm(200mm at first)rear tire.i fab my own countershaft sprockets(3/8's offset).i have a pmfr rear sprocket that fits the r1 rear wheel.i am running an rk x-ring chain and 18/36 gearing.
  • ready2ryde1985
  • ready2ryde1985's Avatar
  • got to love these kzs
29 Jun 2010 10:22
#378972
Dennis Kirk has a kit thats how I did mine . I run a 530 mvx o ring x ring chain and love it !
My chain wasnt cheep lol but I guess you get what you pay for. the sprokits bolt right on and i think the front had a shim or somethin . if you go to there site they are great about sendin a catolog. metric 2010
84 kz 700 a1
82 kz550 ltd
  • dutchz
  • dutchz's Avatar
29 Jun 2010 17:09
#379051
If your bike has the stock arm and rear tire it's real easy. Z1 Enterprises has the sprockets and chain and a guide on the 530 conversion to calculate your ratio:
www.z1enterprises.com/catalog.aspx?pid=KZ1000-D3-1980-MP1
1974 Kawasaki Z1
Stock front hub and rear axle.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
06 Jul 2010 14:51
#380622
another option may be a reverse offset rear sprocket. this will move the chain away from the shock and towards the tire. u will have to do some research to find 1 but they are out there. this will only get u about 1/16" unless u get 1 cusom made.Leon may be able to help u there.
look at this example of a kz1000 525 chain this will give u an idea. if u search this data u may find what u need. just referance the hole spacing and spline. or call them for advice. u may be able to mill the sprocket hub as another option. thats what i did to my zrx12 hub.
www.jtsprockets.com/52.0.html?&L=0&sel_uid=1156&p=
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
