SSS question
- jus1975
- www.tripleaperformance.com
SSS question
28 Jun 2010 07:53
I'm was wanting to attempt to build my own SSS. I have a few designs but the only problem Im having is the hub design. i havent seen one and Im not sure how to design one. Can you guys give some insight and advice on this. How about some pics of the hubs.
Thanks
Thanks
- porchev914
Re: SSS question
28 Jun 2010 08:58
Think of it like a reverse standard hub. The sprocket still goes on the left of the hub, and the brake rotor still goes on the right. The difference being that the hub doesn't spin on and axle, the hub IS the axle. A really big axle riding on big bearing carried in the end of the swingarm. It may be easier to buy an eBay Duc hub and build the end of your swingarm around that :woohoo:
FRANKEN Z!
Re: SSS question
28 Jun 2010 11:41 - 28 Jun 2010 11:43
maybe this pic will help.
i would get the wheel i wanted and reverse engineer the swingarm from there,hth.
Last edit: 28 Jun 2010 11:43 by 531blackbanshee.
Re: SSS question
28 Jun 2010 11:47
or do it car wheel style with a stub spindle built solid into the swingarm then attach the brake rotor and sprocket carrier to the back of the hub.
- porchev914
Re: SSS question
28 Jun 2010 13:38
But if you did that Leon, wouldn't the sprocket and brake disk need to be on the same side as the wheel?
FRANKEN Z!
Re: SSS question
29 Jun 2010 06:49
porchev,
the ideal way would be the way your swingarm is designed or the pic i showed.yes packaging becomes a problem,as it all gets packed very close.
here is one way to deal with the brake tho,
- porchev914
Re: SSS question
29 Jun 2010 08:48
That's what I though.... holy crap someone went to a lot of trouble to adapt a sssa on kz Leon! Do you have a pic of the whole bike? Man, I though I went to a lot of trouble!
FRANKEN Z!
Re: SSS question
29 Jun 2010 09:17 - 29 Jun 2010 09:43probably not the view you wanted porchev but thats all i got.
the one thing that i don't like about a sssa is when the wheel center is offset.it makes them look like the front wheel off of a front wheel drive car.not as noticeable with spokes tho.
Last edit: 29 Jun 2010 09:43 by 531blackbanshee.
Re: SSS question
29 Jun 2010 09:42
- jus1975
Re: SSS question
02 Jul 2010 04:53
thanks for the help. I think Ill get one and use it to mock up on
