sprockets
  • fat z
  • fat z's Avatar Topic Author
sprockets
24 Jun 2010 17:25 - 24 Jun 2010 17:35
#378017
On my kz900 i have a 16t front sprocket, with an 18 inch rear wheel.It has a 46t rear sprocket on it now, and that seems like its too much gear i also have a 38t sprocket which was alrite but i wanted a little more "off the line" my question is, what would be a good rear sprocket that would give me a good take off, but not rev to death on the freeway. thnx.
Last edit: 24 Jun 2010 17:35 by fat z.
  • PLUMMEN
  • PLUMMEN's Avatar
Re: sprockets
24 Jun 2010 17:52
#378022
530 or 630 chain?
  • fat z
Re: sprockets
24 Jun 2010 18:16 - 24 Jun 2010 18:20
#378035
530. and the motor isnt stock either.
Last edit: 24 Jun 2010 18:20 by fat z.
  • PLUMMEN
  • PLUMMEN's Avatar
Re: sprockets
24 Jun 2010 18:24
#378040
ok so what are you wanting it to do? i run a 16x40 530 on my 1327 with a 16" rear wheel,which im guessing isnt too much shorter than an average 18" wheel.
my tach/speedo dont work but im guessing it winds out around 120 or so but gets there pretty quickly B)
  • fat z
Re: sprockets
25 Jun 2010 06:01
#378118
Well, its ridden daily. i wanted a set up that isnt too hard on the motor. like rite now with the 46t rear my fifth gear is like third gear, i can hit it in fifth and it takes off fast, which is fun, but when i back off or i am just buzzing around town in fifth it sounds like i need another gear. when im going slow and just putting around its not so bad, but i dont putt around much.
