rear brake squeal but indicator still in "usable..
21 Jun 2010 21:10 #377457 by kz.chris
the brake indicator is about halfway in the "Usable range"
its a 1977 650.
Any ideas?
Thanks,
1977 Kawasaki KZ650
21 Jun 2010 21:20 #377460 by bountyhunter
Replied by bountyhunter on topic rear brake squeal but indicator still in "usable..
Most aftermarket pads don't have the "squeal shim" on the back like factory pads. Mine squeal too, when you are old like me your hearing goes and it doesn't bother you anymore.:laugh:
  • testarossa
21 Jun 2010 21:35 #377462 by testarossa
You might try a little copper anti-sieze on the back of the pads. Please make sure that you do not put it on the friction surface. Put it on the metal backing plate where it contacts the piston and the caliper. Sometimes this helps.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
21 Jun 2010 21:44 - 21 Jun 2010 21:49 #377464 by kz.chris
Thanks for the replies. i forgot to mention that the rear brake is a drum :blink:
does that make a difference?
1977 Kawasaki KZ650
Last edit: 21 Jun 2010 21:49 by kz.chris.
21 Jun 2010 21:51 - 21 Jun 2010 22:08 #377466 by Patton
With drum brake, noise during brake application may be caused by dust, dirt, grit, etc. inside where the linings are rubbing against the drum.
Would disassemble the rear brake, and wipe it clean, being careful not to get any foreign substance on the linings or drum face surfaces. An air pressure blow gun is also helpful.
Won't hurt to scuff the linings with some fine dry sandpaper before re-assembly. Re-blow and re-wipe.
Inspect the linings for any apparent cracks or damage or excessive wear.
Rear drum brake linings may last a long time. Be sure the bonding between linings and shoes remains tight.
Good Fortune! :)
Last edit: 21 Jun 2010 22:08 by Patton.
  • testarossa
21 Jun 2010 21:58 #377470 by testarossa
Replied by testarossa on topic rear brake squeal but indicator still in
In light of this, please disregard my advice. Do what Patton says, it's good advice. I was thinking disk brakes.
2004 ZX-10R
Angola, IN
21 Jun 2010 22:14 #377473 by kz.chris
Thanks guys ill give that a shot!
1977 Kawasaki KZ650
22 Jun 2010 04:27 - 22 Jun 2010 04:36 #377485 by Old Man Rock
Replied by Old Man Rock on topic rear brake squeal but indicator still in "usable..
Well hell, if you have to go through the trouble of disassembling, drum brake shoes are fairly cheap right and if already half worn... Possibly they started glazing on ya....
Swap them puppies out and clean as advised and be done with it... Ride on....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 22 Jun 2010 04:36 by Old Man Rock.
22 Jun 2010 04:34 - 22 Jun 2010 04:41 #377488 by Patton
Per FSM for Z1, brake lining thickness standard is .1909~.2146" (4.85~5.45mm), with service limit (thinnest acceptable) @ .079" (2.00mm).
If needed ---
Click > Brake shoes from Z1E
Good Fortune! :)
Last edit: 22 Jun 2010 04:41 by Patton.
22 Jun 2010 05:12 #377497 by JMKZHI
Replied by JMKZHI on topic rear brake squeal but indicator still in
kz.chris wrote:
... i forgot to mention that the rear brake is a drum ...
If the age of the rear brake shoes cannot be identified, replace them.
The adhesive that binds the lining to the shoe can fail over time. When it happens, the lining comes off & gets jammed between the shoe & drum, locking the rear wheel. It happened to me when rolling the bike off the centerstand.... very lucky. I'd hate to have it happen at speed. I was also lucky in that it happened in the driveway, so all I had to do was put a piece of cardboard under the rear wheel & slide it into the garage. It would be a drag for it to happen miles from home... for lack of basic maintenance.
22 Jun 2010 07:10 #377512 by T_Dub
Replied by T_Dub on topic rear brake squeal but indicator still in
On my 77 650, I don't use my rear brake, front works fine. But I guess its nice to have it there.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
22 Jun 2010 07:53 - 22 Jun 2010 08:07 #377518 by kz.chris
Replied by kz.chris on topic rear brake squeal but indicator still in
Wow! Glad it worked out OK.
1977 Kawasaki KZ650
Last edit: 22 Jun 2010 08:07 by kz.chris.
