steel brake line kits..any recomended makers?
- trianglelaguna
Re: steel brake line kits..any recomended makers?
25 Feb 2011 09:59
okay..lemme search em and see the skiny...i get my head wrapped around one plan ,and it takes some doing to re route ...i like the idea (very much) of building my lines to my bends and routing and lengths...also would bite to have them use a bend or fitting that in its final setting is facing weird ect....
if i could buy the lines and fittings to assemble my own needs ,in the colors i wanted,(maybe too much to ask on colors) but if i can get the kit or parts and build em right as i assemble that area anyways for other stuff....that will be ideal....
thanks guys...lemme look into those names
Craig
Craig
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- hocbj23
- MFolks
25 Feb 2011 10:59
Brake Lines
www.spieglerusa.com/cfm/brakelines.cfm
www.helusa.com
www.russellperformance.com/metric_two-line.shtml
www.goodridge.co.uk/motorcycle-brake-lines/kawasaki.htm
www.helusa.com
- trianglelaguna
25 Feb 2011 11:17
thanks M
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
- mtbspeedfreak
25 Feb 2011 12:34
mark1122 wrote:
What were the price on the Galfer lines, if you don't mind sharing?
I have the Galfer lines on mine. very purdy in Smoke(carbon fiber look) and gold. they will custom fit too.
www.galferusa.com/html/ss_line_kits.html
2000 ZRX 1100
1976 KZ 900- Daily Driver
- mtbspeedfreak
25 Feb 2011 12:35
Another option:
inlinetube.com/
I got a set of SS brake hoses made for my van. Pretty bitchin! High quality for sure!
2000 ZRX 1100
- cyclhed
13 Mar 2011 12:31 - 13 Mar 2011 12:34
I just installed a set of braided lines on my 1000 CSR yesterday. The 3 piece kit is made by Galfer. I purchased it online from Pasnit.com for $89.95 and it included stainless banjo bolts and copper seals, plus four extra seals. The lower lines fit perfectly - the banjos were installed at 90 degrees to each other just as the originals. The upper line I had to twist about 45 degrees to install and it has a slight twist, but not really a problem. The upper hose banjos should be installed parallel to be correct. Anyway I think the price was good for what you get and you can order in a large variety of colors for the same price. If you live in CA they will charge you 9% sales tax, however the shipping is free to anywhere in the US.
www.pashnit.com/product/index_galfer.html#brakelines
I ran into another problem: the sight glass on my master cylinder has a stone chip that turned into a leaking crack after I tightened the upper brake hose and removed the lid and filled the reservoir. I am going to order a new sight glass from here tomorrow. I found the link on the forum.
www.newrivercyclesalvage.com/sight%20glass.html
Since Pashnit did not have the rear line for my bike in the correct length (16") I ordered one from Z1 Enterprises. I ordered one 13" Goodridge line and two straight chrome banjos - the banjos are 1.5" each for a total length of 16". I have not received the line yet. The cost was about $33 for the three pieces not including shipping.
Past:
1972 175 F7
1974 KZ400
1981 GPZ550
1980 KZ750 LTD
1978 KZ1000
1968 H1500 Mach III
Present:
1982 KZ1000 M2 CSR
1972 175 F7
1974 KZ400
1981 GPZ550
1980 KZ750 LTD
1978 KZ1000
1968 H1500 Mach III
Present:
1982 KZ1000 M2 CSR
Last edit: 13 Mar 2011 12:34 by cyclhed. Reason: pictures
- cyclhed
13 Mar 2011 12:38
I tried to add pictures to my previous post, but something didn't work quite right...andyway here you see the twist in the upper line. I think it's acceptable even though it's not perfect.
Past:
1972 175 F7
1974 KZ400
1981 GPZ550
1980 KZ750 LTD
1978 KZ1000
1968 H1500 Mach III
Present:
1982 KZ1000 M2 CSR
1972 175 F7
1974 KZ400
1981 GPZ550
1980 KZ750 LTD
1978 KZ1000
1968 H1500 Mach III
Present:
1982 KZ1000 M2 CSR
- cyclhed
13 Mar 2011 12:43
Past:
1972 175 F7
1974 KZ400
1981 GPZ550
1980 KZ750 LTD
1978 KZ1000
1968 H1500 Mach III
Present:
1982 KZ1000 M2 CSR
1972 175 F7
1974 KZ400
1981 GPZ550
1980 KZ750 LTD
1978 KZ1000
1968 H1500 Mach III
Present:
1982 KZ1000 M2 CSR
- cyclhed
13 Mar 2011 12:44
Past:
1972 175 F7
1974 KZ400
1981 GPZ550
1980 KZ750 LTD
1978 KZ1000
1968 H1500 Mach III
Present:
1982 KZ1000 M2 CSR
1972 175 F7
1974 KZ400
1981 GPZ550
1980 KZ750 LTD
1978 KZ1000
1968 H1500 Mach III
Present:
1982 KZ1000 M2 CSR
- cyclhed
13 Mar 2011 12:45
Past:
1972 175 F7
1974 KZ400
1981 GPZ550
1980 KZ750 LTD
1978 KZ1000
1968 H1500 Mach III
Present:
1982 KZ1000 M2 CSR
1972 175 F7
1974 KZ400
1981 GPZ550
1980 KZ750 LTD
1978 KZ1000
1968 H1500 Mach III
Present:
1982 KZ1000 M2 CSR
- cyclhed
13 Mar 2011 12:46
Past:
1972 175 F7
1974 KZ400
1981 GPZ550
1980 KZ750 LTD
1978 KZ1000
1968 H1500 Mach III
Present:
1982 KZ1000 M2 CSR
1972 175 F7
1974 KZ400
1981 GPZ550
1980 KZ750 LTD
1978 KZ1000
1968 H1500 Mach III
Present:
1982 KZ1000 M2 CSR
