Hand Grips
- paul714
Hand Grips
15 Jun 2010 19:20
Looking for a replacement hand grip for my 80 Z1r. Anyone recommend a decent grip-I am not a fan of the foam grips-also are both sides the same size-Thanks
- trianglelaguna
Re: Hand Grips
15 Jun 2010 19:31
these are the best grips ever made imo......simple terrific feedback and low effort to hold.....imo
shop.ebay.com/i.html?_nkw=oury++motorcyc...sid=p3286.m270.l1313
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- otakar
Re: Hand Grips
15 Jun 2010 19:39
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- pugsley
Re: Hand Grips
15 Jun 2010 20:03
I like the Oury grips also but I would say order them from Jeff at Z1.
Pugs
Pugs
1983 KZ750F1 shaftie, 1980 KZ750H1
- RonKZ650
Re: Hand Grips
15 Jun 2010 20:10 - 15 Jun 2010 20:20
Foam grips are crap, they harden and get slick. Ourys are OK but wear like an old tire. The stock grips are by far the best. They were still available last I looked, but many years ago. Don't expect to buy a Chinese hand grip touted as the Holy Grail and have it work any better than stock. Part of the appeal of aftermarket crap grips is they are "soft", "large diameter", any of a number of bogus ideas, but in the long run they stink compared to stock. My Dad did those foams on an old Goldwing, gads what junk. And to answer the question about both sides being the same, no they aren't. Stock Kawasaki comes with the complete throttle tube as part of the right grip. It's simply a plug and play. Buy aftermarket and the right "should be" bigger inner diameter than the left to accomodate the tube. I wouldn't bet on this in this day and age though, they may expect you to put a 3/4" diameter grip over a 1" tube or vise versa. Got to love modern aftermarket. :X You then have to pry your old grip off the tube. Also many aftermarket grips are too short so you have to either hacksaw off part of your tube or put up with a 1/2" ugly gaping gap. Then for sure whatever glue you use will not work and the grip will rotate all goofy on the tube. Needless to expand any further in this boredom, but if you have stock grips, keep them, if not get them.
Last edit: 15 Jun 2010 20:20 by RonKZ650.
- trianglelaguna
Re: Hand Grips
15 Jun 2010 20:37
dont listen those guys or you'll be sorry 9 outta ten dentists recomend oury to their patients who chew gum....
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
- RonKZ650
Re: Hand Grips
16 Jun 2010 10:16
Be sure if you get the Oury to inquire on the date stamp. You can't use them if they are over 2 yrs old as rubber is no longer safe after that long. Also replace when tread wears to 2/32" regardless of age.
- anarki650
Re: Hand Grips
16 Jun 2010 10:22
otakar wrote:
+1, a set of these are always one of the first things I do to a new bike...even my brand new ER6n!
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Omaha NE
- bountyhunter
Re: Hand Grips
16 Jun 2010 11:04
RonKZ650 wrote:
How often do you have to rotate them?
- Chopper513
Re: Hand Grips
16 Jun 2010 11:19
I have a 1980 kz1000 mark2 chain drive bike that I am doing a frame off restoration on
and need actual pictures of electrical component placement behind left side cover to finsh assembly any help would be apreciated e-mail photos to
chopper513@yahoo.com
thank you
thank you
Re: Hand Grips
16 Jun 2010 12:55
Chopper513 wrote:
If you're doing a restoration definitely go with stock; anything else will stick out like a sore thumb. Ed
I have a 1980 kz1000 mark2 chain drive bike that I am doing a frame off restoration on...
Re: Hand Grips
16 Jun 2010 16:18 - 16 Jun 2010 16:20
No eBay APP ID and/or Cert ID defined in Kunena configurationMy faves.
On and off in seconds using compressed air rubber cone tip between edge of grip and handlebar, and no glue or hairspray needed.
Have not hardened, but bike is garaged.
5" length is 1/8" shorter than oem KZ900-B1 LTD.
Last edit: 16 Jun 2010 16:20 by Patton.
