automatic timing chain adjuster
  • lostkatt
  • lostkatt's Avatar Topic Author
13 Jun 2010 17:28
#375531
Can anyone tell me how to reset automatic timing chain adjuster. Do i have to take it off or can i make the adjustment with it still on.
  • Motor Head
  • Motor Head's Avatar
Re: automatic timing chain adjuster
13 Jun 2010 17:45
#375538
Tell us what bike you got? Do you have a manual for your model?
  • lostkatt
14 Jun 2010 08:00
#375632
I have a 1980 kz750 and no i dont have a manuel.
  • hocbj23
  • hocbj23's Avatar
14 Jun 2010 11:11
#375657
If the 750 adjuster is like the 1000 adjuster,there is no readjustment.U have to take the thing all the way off and reset it according to the manual,then reinstall it.If u take it part way out and then put it back in,u may screw up the timing chain and damage the engine.Spend a few bucks on a manual for the bike and they will tell u how to in easy steps.OR get an APE manual adjuster and throw the "automatic" one away.bj
  • MFolks
  • MFolks's Avatar
14 Jun 2010 11:13
#375658
Here's another manual cam chain adjuster:
www.kriegercamchaintensioners.com/
14 Jun 2010 12:55 - 14 Jun 2010 13:38
#375691
According to kawasaki.com, the oem '80KZ750 cam chain adjuster is same as '79KZ1000 (see images in following posts):
Good Fortune! :)
Last edit: 14 Jun 2010 13:38 by Patton.
14 Jun 2010 13:40
#375710
14 Jun 2010 13:51 - 14 Jun 2010 13:53
#375714
Sorry about being barely legible
May click on image to enlarge, which helps a little.
Last edit: 14 Jun 2010 13:53 by Patton.
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
14 Jun 2010 15:42
#375740
I usally use a guitar string to hold mine while i get it clamped down. Roy
  • jswag5
  • jswag5's Avatar
  • whats the big deal about harley, i prefer 4 cyls!!
14 Jun 2010 16:00
#375746
guitar strings i have found are essential when working on a motorcycle, they work great for clearing clogged jets in carbs, enrichment jets in fuel bowls, and the larger ones come in handy for tying off cables and wires.
they can even be used to clean threads and removing o-rings from recesses.
i play a little guitar myself and always have some on hand, and if you dont play, most walmarts carry cheap sets(about 5 bucks) to keep around.
think outside the box, and everyday items become lifesaving tools
82 kz1000p
83 yammie xj750mk bobber
78 honda cx500 standard cafe
RECENT 81 honda goldwing(barn fresh with 15000 on the clock)
if you cant fix it with a hammer and duct tape, get a bigger hammer and more duct tape!!
