ltd 750 front caliper upgrade.
  • run990
  • run990's Avatar Topic Author
  • too old & creaky to be messing with bikes
13 Jun 2010 10:08
#375445
hi ,i run an 81 kz750ltd as my daily ride ,bike is ideal however the front brake is either on or off ,no real feel to it .are there any mastercylinders that can be substituted to give more leverage so to speak ,more movement at the bars ,the brakes are efficient enough just damm hard to pull in with no travel at the bars .
the calipers etc are free bike will slow well from any speed i just want to reduce the pressure i need to apply to the lever .
i have got short fingers which is part of my problem ,even a dogleg type lever fitted to the original cylinder would be a help .
someone must have done what i want to do.so any suggestions will be recieved with thanks
1981 kz750 ltd
bad back
arthritic arm
no money
could not be happier .
