timing chain tensioner
  • lostkatt
  • lostkatt's Avatar Topic Author
09 Jun 2010 18:04
#374710
Can someone give me a starting point on what i should do or check on my timing chain tensioner. I have a 1980 kz750, just bought cpl of months ago, rode fine, then one day, sounded like i was running on 2 cyclinders, had someone just take a quick look at it and he seemed to think that got play in timing chain. My question is there a way to check if that is the problem, where would i start without taking too much apart. And can i like reset the tensioner without pulling it off the motor. Thank You for someone to help me out.
  • otakar
  • otakar's Avatar
Re: timing chain tensioner
09 Jun 2010 18:07
#374712
You would know if it is the tensioner because the engine would rattle. A tensioner would not make you loose two of your cylinders.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • lostkatt
09 Jun 2010 18:09
#374713
should i pull the valve cover to see if lost one of the guides or can i reset the tensioner or should i pull it and put on a manual tensioner
  • otakar
  • otakar's Avatar
09 Jun 2010 18:32
#374730
I would mount a manual one anyways, but I think that you either have an ignition problem or a carburetor problem. What two cylinders drop out?
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • basketcase
  • basketcase's Avatar
10 Jun 2010 20:36
#375014
reset the tensioner according to the manual, I did mine and it was real easy after fully understanding what I was trying to accomplish.
1979 KZ750B4
Basketcase
