79 KZ 650 C3---92 zypher 750 swing arm conversion
  • 550A2
  • 550A2's Avatar Topic Author
  • keep the shiny side up
07 Jun 2010 15:28
#374179
Hey everyone. I was doing some reading and im thinking about going through with a swing arm swap. It looks pretty straight forward from what i see here.and i found a cheap one on ebay. forums.kz650.info/index.php?topic=1140
but i was thinking of maybe just using the stock kz 650 wheel and tire instead of the Gpz900r wheel with 1000j hub and sprocket. Would it be possible to do this without having to use an offset sprocket?
spacers arent a problem, i have access to a lathe, and i got family in the fastner buisness.
Any ideas on this conversion would be appritiated very much. or suggestions of other swingers that will work for this bike.
thanks
-Luke
82 Honda ATC 200-sold
82 Yamaha Virago 920-sold
82 Yamaha YZ250j-kept
80 Suzuki GS 550-sold
82 Kawasaki KZ550 A2-ride all the time
79 Kawasaki KZ650 C-sold
73 Kawasaki Z1 900E-paid $200, sold $6000
86 Yamaha Radian YX600-new project
  • PLUMMEN
  • PLUMMEN's Avatar
Re: 79 KZ 650 C3---92 zypher 750 swing arm conversion
07 Jun 2010 15:52
#374185
as long as the axle is same diameter the 650 wheel should work,youll probably have to come up with differant rear brake mount depending on which one you have.
  • otakar
  • otakar's Avatar
07 Jun 2010 16:01
#374193
If you're using the stock wheels you don't have to do anything with the sprockets. You may have to use some shims on the axle to fill in any extra space. Make sure that you use the same amount on both sides of the wheel. If the axle is not the same as the one for your wheel, just change the bearings in the wheel to match the combo.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • Mark Wing
  • Mark Wing's Avatar
07 Jun 2010 16:12
#374200
Also if your axle is bigger than the Zeffer you can drill the eccentrics like I did to put the police wheels on my bike.
Mark
Yorba Linda Cal.
  • 550A2
07 Jun 2010 17:05
#374217
cool thanks.
Soooo...I could stick with the zypher axle that comes with the swinger, and get some bearings with original zypher Inner Diameter to fit zypher axle, and 650 Outer Diameter to fit the 650 hub.
eccentrics will work fine that way. sounds like a plan to me!!!
On the 650info forum, they state that everyting hooks up pretty close with little mod. (brake stay, caliper) but it doesnt always work out perfect... I could make a spacing plate on the caliper bracket to move the caliper in if i need to, to make up for spacers used to center wheel in swingarm.
The swinger comes with, piggyback shocks, caliper, brake stay, axle, fastners, eccentrics and pivot bolt!!!! :)
now its time to BID!
Sounds good!
