Lowering My Bike
  • thequam
  • thequam's Avatar Topic Author
Lowering My Bike
07 Jun 2010 11:43
#374104
I'm sure this was already covered somewhere, but I'm in a bit of a hurry and if anyone could help me out I would appreciate it. I have a 1978 KZ1000 LTD and I want to lower it a bit. I know I can drop the front a bit by sliding the forks up, and I read on here about some lowering brackets that JC Whitney sells but their website said it only fits bikes with rear drum brakes and mine has a rear disk. I don't rally want to buy new shocks and only want a subtle drop, so any advice would be greatly appreciated.
  • kenskz1000
  • kenskz1000's Avatar
Re: Lowering My Bike
07 Jun 2010 13:21
#374136
I have a 77 LTD. Shorter shocks is the route I took. Cutting out an inch of my kick stand also had to be done
  • z1kzonly
  • z1kzonly's Avatar
07 Jun 2010 14:34
#374161
I always cut the stock bottom shock bracket off of the swingarm.
Then drilled a 3/8hole right below that spot.
Dropped the rear an inch or so.
A nice hardened 3/8" bolt and some washers.
Never had a problem.
Still have to lower the kickstand.
You can always find a stock swingarm on ebay to cut or replace down the road for putting back to original.
  • PLUMMEN
  • PLUMMEN's Avatar
07 Jun 2010 15:56
#374188
  • PLUMMEN
  • PLUMMEN's Avatar
07 Jun 2010 15:58
#374190
dont lower the front without first lowering rear of bike,try adjusting preload on rear shocks to lower setting
