GRIMECA REAR BRAKE
  • patmann
  • patmann's Avatar Topic Author
GRIMECA REAR BRAKE
04 Jun 2010 12:14
#373408
Here's the deal/problem TODAY.. on my 74' Z1 the first owner wanted it to look like my 1977 1000 LTD and stop like it. So he did a Grimeca rear brake conversion on it twenty plus years ago.
It's now starting to make some noises, strange to describe.
Kinda' a eerk/squeak ish noise, NOT a grinding sound at all, but if I touch the rear pedal it stops.
I'm torn between riding it as is, and tearing into it.
I can't seem to find the correct shoes for it IF it is them ( and I highly doubt it is from the sounds ).
As mine are different from all I have found.
Any ideas????
Pat
1974 900 Z1 modified to look like a LTD , some engine mods. But I still have all the original parts.
1977 1000 project bike
1972 H1 project bike
If pro is opposite of con, then what is the opposite of progress?
  • hocbj23
  • hocbj23's Avatar
Re: GRIMECA REAR BRAKE
04 Jun 2010 12:40
#373410
"If pro is the opposite of con,what is the opposite of progress?" Answer: Retrogress--- directly related to CONgress--yes I got it.bj
  • patmann
04 Jun 2010 14:00
#373441
Not what I was looking for.. but ok.
  • PLUMMEN
  • PLUMMEN's Avatar
04 Jun 2010 18:23
#373505
got a picture of the caliper?
  • The Fish
  • The Fish's Avatar
05 Jun 2010 03:53
#373591
Does it look like this(CB 750 Shown)?
If you look at the right hand side of the axle, there is a "slice" in the aluminum caliper bracket. The "slice" has an allen bolt to clamp it in place(around the axle spacer). This is what you use to center the caliper on the disc. If the caliper isn't centered, it can cause all kinds of funkified noises. Also check all of the mounting bolts for looseness.
I forget where I got the brake pads, but they weren't that hard to find. The Grimeca calipers are used in the carting scene. The same exact calipers were also used on a 6 wheeled amphibious thing I had in the shop (I forget the make, but it was made in Canada).
My caliper didn't have any seals in the piston bores when I got it, but the caliper seals for the KZ 900 fit like they were made for it.
  • supercharged
  • supercharged's Avatar
05 Jun 2010 10:22
#373649
Grimecas are still available. I got those for the vetter bike, then switched to the correct Lockheed units.
You mentioned earlier models, do they have solid rotors? If so, I was under the impression that they tend to squeal after the "scuff" went away?
Mike D
- 79 KZ1000 LTD Supercharged
- 80 KZ1000 1105cc Pridmore/Vetter tribute
- 79 Honda CBX
- 03 Z1000 Mod
- 80 KZ1000 LTD Modified
- 80 KZ1000 LTD PROJECT on Hold
- 78 KZ1000/900 - Street big block
- 78 KZ1000-NEEDS HELP!
- 80 CBX -Project STARTED
- 81 GPZ1100
- GSRX1200
- 80 CB750F supersport... eahhh not so good
- 1988 KZ1000 Police - 50K miles
- 1978 KZ1000 LTD - should be a quick project
- 2001 KZ1000 Police - 30K miles - chromed Sgt Bike GREAT SHAPE
