new front forks calipers wont fit them
  • yggy
  • yggy's Avatar Topic Author
  • more wrenching than riding!
Re: new front forks calipers wont fit them
04 Jun 2010 14:10
#373443
Hi all
Didn't have alot of time tonight. But I did do a Quick measurement on the disc. They are 29cm (11.41") in diameter. Does this tell u guys anything ?
Thx
1980 EU-z650 c4 one of the few C's around..
  • otakar
  • otakar's Avatar
04 Jun 2010 16:27 - 04 Jun 2010 16:28
#373476
If you removed the disc, would the caliper mount on the fork? (Is the hole spacing the same?) Or in other words, will the caliper mount if the wheel is off?
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 04 Jun 2010 16:28 by otakar.
  • PLUMMEN
  • PLUMMEN's Avatar
04 Jun 2010 18:20
#373502
yggy wrote:
@plummen
Ok do I need to put some heat on the forks to get them out? My grip tool keeps slipping on the bolts. Maybe they used one of those heavy duty loctites in there.
put a pair of vise grips on the non threaded part,theyll come out.if you leave the forks on bike with fender attached it might be easier to get leverage.
they are the same as the exhuast studs on the 76-80 kz900-1000
  • yggy
06 Jun 2010 02:43
#373835
ok, done and done! just had to buy bigger vise grip and that did the trick easy..
do i have to get the excact studs like the exhaust studs? or is it allowed to take a bolt and chop of the end bit? providing the bolt is up for the task of course..
  • Samwell
  • Samwell's Avatar
06 Jun 2010 04:35
#373840
Exhaust studs from Z1enterprises.com are only $3 and change each. It'd be less hassle then cutting a bolt up, besides, if the bolt breaks you'll be pissed at yourself for trying to save $3!
kawasaki.com has parts diagrams and you can sort out if these studs are the right ones for your brake callipers.
  • Bluemeanie
  • Bluemeanie's Avatar
06 Jun 2010 06:13
#373856
These studs hold your front wheel on so you don't want junk metal screws or studs. Get the right ones!
  • PLUMMEN
  • PLUMMEN's Avatar
06 Jun 2010 08:52
#373883
use new nuts and lock washers also B)
  • yggy
06 Jun 2010 13:25
#373924
ok ok :)
i will take them from the other forks i got :)
and wil get some new nuts and washers :)
06 Jun 2010 15:55
#373957
The axle caps have a front and a back, and must be oriented correctly.
Caps should be installed with the "arrow" on bottom of cap pointing forward.
Good Fortune! :)
